Tocchi
    7
Everything posted by Tocchi
  1. might try to take the boat down soon... if they let me.. 465rwkw & 1000kg car would be safe right? haha otherwise its the FG for a final run of the season
  2. haha touche. in terms of power, I cant comment on the 3+ ... on the other hand, how it handles abuse, I can
  3. 624rwhp @ 25psi. (ovaboost dyno) dyno sheet when I get back to perth later this week. not bad for a BA 4L haha
  4. go the 3+ ... ive done 55,000 hard KMs in my xr8 since getting that clutch, and it has never failed me. as for rims, I wouldnt purchase wheels in WA, except for JPC ... but if I could, id buy from eastern states or overseas, as Perth wheel/tyre companies are ripoffs!
  5. brakes, thanks guys ill need it done when I get back ... its got a 0.5mm lip and some bumps (braking not affected) from track work
  6. where can you get the 355mm rotors skimmed? (I heard you cant get them done?) would I have issues if mine have been cryogenically treated?
  7. ^^ 19x10 +10 front, 19x10.5 +23 rear 245/40 on the front, going to a 245/35 soon (so the front end drops a further 13mm, and a tad more clearance to guards)
  8. I just grabbed a 19" fpv rim for my spare, that way I knew it was going to fit
  9. will do over 20 last time I worked it out
  10. hey Worm, can I play in this thread?
  11. Club Bayview
  12. this is the case. ive had a Dellows, seemingly ok, but needed a few little things cleaned up etc, others have had same issues. PM Dean (Slash, on the forums I believe), he has a T400 setup for sale
  13. unsure. he has a very agricultural setup, but its proven. total different class to me. unsure of specifics of his car to be honest. im going to start with about 550rwhp (going to stretch it to 700 ish on dyno we hope), the car used to run mid high 8s with 680 flywheel hp with the clevo 383 in it. running a 1800hp rated glide. cant remember the company from the US that made it, but its built by Allfast Convertors.
  14. that twin turbo barra torana is now in a B series shell he's run 7s it has: stock motor, stock cams ARP head studs Atomic Oil Pump Gears Atomic Ovate Wire Valve Springs running methanol I can get away with no intercooler as temps will be low. but in future maybe a W2A system. we will find out on the dyno I guess... would be an easy solution if it comes off
  15. was no FB update... just whammo! a few occasional hints but nothing obvious. it's getting tuned this arvo or 2moro ... the video was taken when it had 205/50/R16 tyres on the back, just after video I bolted on the 31x13 R15 tyres for the dyno it's running on meth!
  16. video explains all ...
  17. when I read the title of this topic I keep thinking "I wonder if he has lots of mahagony or leather bound books?" but try Toyos, the Proxe 4s, T1Rs, R1Rs will do what you want
  18. Tocchi
    Etc Fault?
    it has happened twice, first time on a gravel driveway that was like 40 degrees steep, and I started the car with ass end up. haha. then on a level area.
  19. Tocchi
    Etc Fault?
    ETC fault makes my car sound cammed. lol
  20. Tocchi
    Low Spark
    ok update. good news. we had low spark issues still, no matter what we did, a couple of the things were earthing - the car is solid mounted to chassis, that's a decent earth haah. and direct power from battery to start motor, so it was getting enough power. solution: get Glenn Baker the motec guru to help so what we thought were internal ignitors on the coilpacks, arent. haha. we got sparks the size of lightening bolts :D ive got to source a M&W CDI unit, which has 250mJ compared to the Motec's 150mJ unit. anybody got any contacts for M&W products?
  21. 08s are street tyres, R888s are R-comps, pricey ones at that. R888s not good for street unless you like 5,000km out of a set of tyres
  22. will be there to watch Gonzo's BA run
  23. cheers haha NO!!! no new rims... got a new exhaust.. goes into Prestige Exhausts 2moro morning
  24. Tocchi
    Low Spark
    havent had a chance to go to the workshop since last week :( probably will head there next week, so yeah, might be able to source a cheap Motec CDI unit (worst case), so that could help
  25. Deany poo, can you see what andy can do in the 255/40/R19 ? xoxox
