Tocchi
    7
Everything posted by Tocchi
  1. For the record, they are 3 piece ***
  2. I have epic flutter all the time, I touch the accelerator and there's pigeons. Maybe due to my diff ratio loading the engine up ?
  3. Make sure you mark & this retain the cam caps in correct place/position. Otherwise line honing will need to be done, to avoid premature wear as well. Basically just a heads up for people removing them etc, I found out after mixing & matching, but before it was ever near starting
  4. Lol. All that prep Aidan.
  5. Would not use proflow fittings let alone their pump setup... I like things that don't leak
  6. Rumours of 10k L tank
  7. I have a titanium flapper & retainer (unused) I bought off here, for $100, if you're looking for the parts alone
  8. Sorting paperwork & receipts... For the Capri. There's hundreds of receipts. I wish I wasn't into cars haha
  9. Referring to pedders and the other cheaper brands. Haven't had experience with SW
  10. Notably quiet too
  11. Nelsonian has the best longtime track time on a falcon. Check his topics. I've had extensive track time with my old FG, probably 5,000km ish over the years I had it... BRAKE FLUID is key. I used PMU GFour fluid and it was amazing. Suspension is next up. A good set of springs and shocks will out perform cheap coilovers etc.
  12. The nizpro cobra kit was a c*nt to fit with the limited instructions available online. In saying that, top notch quality.
  13. I remember when a wide set of Simmons without Tyres was near upon 5k ... How times change. #oldmanhere
  14. Up the boost. Big turbo & Small gate - high boost is one way to bandaid the issue. Big turbo & big gate - low boost / high boost will have no dramas for boost control
  15. I run a 245/45/17 on the BF's front - no rubbing or anything.
  16. Work got an uber account for the employees - no more crap taxis woohoo
  17. Currently working at a BHP power station, everybody looked so happy, so I asked them how they find the job ... They said "it was a gas"
  18. What a lot of us (racers) do with gauges is mount them so operating temperature/pressure is upright so at quick glance we know exactly if it's good/bad. As Arron said, unless you're looking at them when sh*t goes bang, there's not much point ... So a gauge with a peak hold setting etc - a form of (soft) datalogging (where the data is reset every time the cars power is turned off)
  19. Are Toyo R1R still made ?
  20. It will be interesting to see if the track of them is different to brembos. And if there is, that difference is obviously the track pedigree.
  21. Beget, is that a French dish like the carburetor ?
  22. Picasso ! Only one flaw, the wagon only leaves one. Haha
  23. Ok Dom Torreto.
