dansedgli
1 Neutral
  1. Does it have a bellhousing?
  2. Does anyone know how much 42lb injectors would be good for on e85? Its not a BA so not chasing over 300.
  3. It was good knowing it wouldn't break it but Ive gone back to auto since.
  4. Yes with a bit of work. I had one in my AU.
  5. Are you sure? He recommends *Beep* gets wog tuned. http://www.fordforums.com.au/showthread.php?t=11339691
  6. OverDrive is a 4th gear.
  7. Dont drop it on your head. Its heavy.
  8. http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-037&Category_Code=GTH
  9. http://atpturbo.com/
  10. Heaps of non B series turbo falcons on this site: http://www.boostedfalcon.net/ I'd buy a BA next time too.
  11. Did they give you any advice on how to cut the old one off?
  12. This catalogue? http://www.dellowconversions.com.au/images/DellowAutomotive.pdf
  13. The bellhousing on a T400 is part of the case. It will need to be cut off before an adapter plate or custom bellhousing can be used. The adapter would need to bolt to the pump. KEAS can do it if they are still around. The cut the bellhousing off and make an adpater plate to fit the T400 to an old EA 3 speed bellhousing which bolts onto an XR6T motor. Not sure if anyone else does it. It wouldnt be too hard for a decent shop to make I imagine. Here's one for a t400 to supra bellhousing.
  14. Is a 2 link just tramp rods?
