silverbolt
1 Neutral
About silverbolt
  • Birthday 23/08/1979
    Sydney
Contact Methods
  • Yahoo
    arif_bluescope@yahoo.com
  1. Happy Birthday silverbolt!
  2. Happy Birthday silverbolt!
  3. Happy Birthday silverbolt!
  4. Happy Birthday silverbolt!
  5. My one has about 115000 km on it. No issues with trans but thought to ask the question as I do not get consistent answers from Ford service centers. I was thinking of doing pan/gasket and filter as you suggested. Any place you recommend in Sydney apart from Ford Service Center....
  6. how much does it cost? By the way why ford is saying it is sealed for life....I call 2 ford dealers and both gave me different answers. One said its sealed for life and the other one said every 200000Ks............confused
  7. Can anyone advise me what is the recommended duration for changing transmission oil and filters for BF MK2 6 speed gearbox (automatic)
  8. The tint is black one....am not sure of the percentage but its ex cop undercover vehicle so tint has to be legal I believe......................
  9. Friends My car has got premium sounds but the reception for radio is very poor....I cant tune into AM at all and few FM stations but the reception is not consistant as you drive. Is this a common problem or someting wrong.......
  10. Sorry..I should have been more detailed.... I have bought Ozegauge which can be preset to a desired level. If the readings go beyond the preset level then warning light and alarm will come up....
  11. Friends I have a 2007 BF MKII FALCON XR6T Dec 2007 built date. To what setting can I preset my Boost Pressure, Oil Pressure and Oil Temperature to on the gauges..... Any idea??
  12. Do we have to put thread seal tape when we connet the sandwich plate to the engine block??
  13. Just wondering if anyone could help me out on the instalation of oil temperature in oil pressure gauge. How can the sensors be installed. With a TEE connection only one sensor can be done....what about the other sensor....
  14. Friends Lask week I was on the forum asking about gauges for my BF MKII Falcon XR6T. Well after getting all your advice I have bought a tripod from Pole position and ozegauges from Scott. Thanks to you all... Expecting delivery soon. I was going through the installation guide and what confused me a bit is the installation of oil pressure and oil temperature gauge. The installation guide shows that both the sensors are installed at the same place. So if a TEE arrangement is used then we can only install one sensor, either pressure or temp.....can I put two TEE connections and use one for each? By extending the distance of the line to the existing oil pressure sesor will have any effect on existing pressure switch. Please advice if this is appropriate or there is any other method
  15. Friends Anyone used those Supercheap auto gauges called "Calibre" All electrical (except boost and vac) Come with all senders and wiring, range from like $50 to $70 for the 52mm
