QA50
3 Neutral
  1. Reverse the polarity of the stock sub. They are out of phase from the factory. It makes a big difference to the overall sound and costs you nothing.
  2. Not a huge amount of mods to get there but yes, you'll need bigger injectors. So far its fine without the LSD. Have a look in this thread: http://www.fordxr6turbo.com/forum/topic/76565-black-g6et-50th/page__view__findpost__p__1134725 The little FG turbo runs out of puff at about the same time the exhaust becomes a restriction anyway. Unless you are upgrading the turbo in the search of more power or just want the sound, I reckon keep it stock.
  3. Just do the cat. Mine made over 320rwkw with the stock exhaust - just a high flow cat added. Same sound level as factory.
  4. Is this tuned yet? If so, how is it?
  5. QA50
    Black G6Et 50Th
    Cheers. The photo shows the cooler more than in real life too. It's a true sleeper at the moment! Only thing I don't like under the bonnet is the BOV outlet hose. Looks ugly. I think I'll look at doing something else there.
  6. QA50
    Black G6Et 50Th
    I'm using the Process West turbo side intake. Here are some photos and a dyno sheet:
  7. QA50
    Black G6Et 50Th
    Im really suprised how well it puts the power down to be honest. When provoked it will fry the tyres but generally its fine. Also suprising how well the open center diff goes. Always spins both tyres...
  8. QA50
    Black G6Et 50Th
    Yep. Doing it easy. Turbo port definately did work - 12psi flat right through, juuuust tailing off at the end due to the stock exhaust. Stock exhaust still. Turbo wont make a whole lot more than that anyway - as Mexicanbatman eluded to. You gotta pay to play. Simple as that. Insurance isnt a problem with Shannons. Cost a fair bit. I could have done it a lot cheaper without going for things like the PW stage 3 and the ID injectors. Call up Mick or Bel and they'll set you straight on prices.
  9. QA50
    Black G6Et 50Th
    So I picked this up from Pitlane today. Wow. It seriously hauls! 316rwkw at a lazy 12psi! Very happy with it and the crew at Pitlane Performance. Highly recommended.
  10. QA50
    Black G6Et 50Th
    Im upgrading it because it's cheap insurance for me at the power level I'll be at. Car was dropped off this morning at Pit Lane Performance. Can't wait to see how it drives afterwards!
  11. QA50
    Black G6Et 50Th
    Fuel pump will be a Walbro in-tank. Next round of mods I'll do a surge tank andexternal bosch.
  12. QA50
    Black G6Et 50Th
    Thanks guys. Goes to Pitlane next week for ID1000 injectors, fuel pump, turbo port/actuator, ecu and ZF tune, cat and thermostat. Hoping for 300rwkw +
  13. QA50
    Black G6Et 50Th
    Stage 3. Veeerrrry tight fit!
  14. QA50
    Black G6Et 50Th
    Before and after
  15. QA50
    Black G6Et 50Th
    First bits purchased for it: Booked in for more go fast bits in November. Giddyup.
