falcon_6
About falcon_6
  • Birthday 02/10/1970
    Bringelly NSW
  • Interests
    shooting cars sport
1,522 profile views
  1. Happy Birthday falcon_6!
  2. Happy Birthday falcon_6!
  3. Happy Birthday falcon_6!
  4. As per phone call.
    My banking details are.
    P.Roncevic
    NAB
    bsb-082-282
    acc-690137791
    I'm organising a courier through my wifes work.
  5. Hi Paul,
    Send me your bank info and I will do a deposit of $1000 Today and Balance $800 on thursday..
    Delivery/ insurance instructions:
    Mark Johnston
    C/o WINSULATION
    Factory 15/62 Bishop Street
    Kelvin Grove Qld 4059
    Contact: 07 3356 5133
    Mob: 0434 263 515
    Cheers,
    Mark.
  6. Faulty wastegate actuator or sticky waste gate
  7. I have the same setup. It took me quite a while to get used to the noise. Not much you can do.
  8. Looking at your dyno charts, its impossible for your turbo to hold boost the way it is at that power level without having boost leak. These 35/40 turbos are internally gated and cannot handle big boost levels even when ported. It seems to me like your turbo has already been moded.
  9. They are a wrecker,but do supply and fit as well
  10. falcon_6
    Oil Leak
    Just wondering if some of you turbo folks out there can offer comments on my slight problem. I'm running stage 3 process west kit and the usual goodies with 380rwkw 16psi as my daily gay tune. Now have any of you came across issues with oil leaks from the engine due to the crank case pressurizing.This is generally caused by blowby from high boost levels. Now since I'm running large power levels do I require extra crank case ventilation( the one in the middle of the rocker cover not the pcv)? If so what is the best way to go by thiss?
  11. What would the difference in power be if the air temp was 31c and intake 27c. Will the warmer conditions cause ecu to take out timing,lean out. If I was doing 375rwkw on a 31c day,would it show more on 20c day. I was told that the dyno shows more on a warmer day. What power difference would your shoot 6f show if you run your car on a warm day say 30c.I noticed it was run on a very cold day.
  12. has not set their status
  13. Liberty servo at sunnyholt rd blacktown
