liontamer2
Everything posted by liontamer2
  1. Don't realy know but if you talk to Drew he will...Greg
  2. Hi guys,I have had 2 pwr intercoolers on my ute the first one a stanard fitment one whitch flowed across the bottom of the tank then back through the top it lost 6 lb of boost,then I met Drew at pwr one of the most helpfull people I have met,after many fax's and design's came up with one that gained 3 lb of boost still standard fitment, about 2.5 times bigger than standard and works very well for the price.am running around 290 rwkw and looking for more..Greg
  3. liontamer2
    ute register
    Phamtom,lowered 50mm front,70 mm rear,JVC head unit,12 inch Fusion sub driven buy a Fusion 600 amp amp,Boston splits up front and Boston 7x5 rear,4 inch turbo back SMB zorst.larger intercooler.injectors.valve springs,unichip,cold air induction,water spray,cross drilled and slotted brakes all round, member 12 second club........and going for more
  4. Will be there with bells on........
  5. I ran a 13.2 @111mph so am quite happy (pb is 12.88 @ 112mph) in my T.
  6. unichip,exhaust,valve springs,injectors,fuel pump,engine oil cooler,new improved pwr intercooler,ss inductions,auto upgrade,300rwkw, 12 second club and loving it..........
  7. Fitted a replacement PWR intercooler to my BA XR6 Turbo then had it run up on a dyno thinking that well maybe another 20 rwkw but surprise surprise no go, had 14 psi at turbo and only 7.5 at the inlet side well well you might say, then refitted the stanard intercooler and it was only loseing 1.5 psi at the lower end and about 3 psi at the top end with around 250 rwkw. My query is has anyone had a similar problem with PWR's intercooler. Many thanks Greg..........
  8. spent $4300.00 on ute so far 260 rwkw very happy with result 82 rwkw up on standard @ $51.80/kw.
  9. help..what switch is the oil pressure switch,is it the one above the oil filter or the one on the turbo oil feed about 70mm. behind it. with thanks.greg
  10. mines factory fitted and has rubbers around sports bar
