liontamer2
Everything posted by liontamer2
  1. liontamer2
    Geea's New Pb
    Well done Craig
  2. My ute runs constant 12.8's fitted a Trans Mod 12.3's best $85.00 ever spent
  3. The ute ran a PB tonight at Willowbank,still pumped, F.I.S.T have done it again after fitting a Trans Module shaved over half a second of my time,bloody 12.30 still Thanks AL at F.I.S.T
  4. forgot to say that I put in a maual button so can give a few squirts before take offfffffffff
  5. Well done FPVT6 same time as liontamer 12.86 but mines doing 116 mph might get Jeff to give mine a squrit ....Greg
  6. I myself plumbed in another window washer pump into the washer bottle,used a 4psi Hobbs pressure switch (p/n sw p 76583/4) $32.00 a small garden sprinkler,small lcd light wala $50.00 works a treat Greg
  7. Hi, just bump it forward with the palm of your hand then push the plastic pin out refit the sinker back in the handle replace the spring and plastic pin,pratice makes perfect as have done it a few times now only 5 minutes to fix,new ones cost $28.00 cable and all,sh*t plastic
  8. Hi FPVT6, a few more shinny bit might be the go,looks bloody good though,Al at F.I.S.T comes up with some good ideas eh. will be getting the rest painted very soon..Greg
  9. Hi zapXR6T, 315 rwkw
  10. Many thanks Jeff and all the boys at F.I.S.T
  11. My ute gained 3 lb. of boost wiht the PWR I/c have since changed the piping from I/c to the inlet as its only 50mm where it goes under the battery, fitted a new 4inch exhust,968 injectors,tuned by FIST 300 + rwkw 1/4 mile speed 116mph next the auto.....Greg
  12. Jeff lets not mention kw's at the moment
  13. Sounds like those boys at FIST know there stuff
  14. Jeff does this mean that my ute is not on the dyno at this moment
  15. might as well come along for the ride
  16. No fcuking worries Jeff...........
  17. Seen Jeff's dyno sheet today and he's right only 415 rwkw
  18. Mine has two one above and one down low
  19. that's the power stearing cooler the trans cooler is in the radiator only on my T ute
  20. Thanks BlownBA
  21. Hi all,can someone tell me what pipe is the return pipe on the trans oil cooler is it the top or bottom one.many thanks Greg
  22. Hi Sixrt, boost was up just over 12psi had it backed of to 10.5 was told that injectors and 3" exhust just not up for more but was getting around 290rwkw,now looking for more.Greg
  23. Hi Scotty, I am working on a few mods at the moment eg. 4" exhust,revised plumbing,yet another set of injectors then BOSS edit all before the trip to Darwin.Greg
  24. photo's of piping changes........
  25. photo's of piping changes........
