Well, no oil pressure issues in my engine, it is a bit low at 600 rpm, but nothing which is a cause for concern, as engine is not loaded anyway, and it's not low enough to light the oil pressure warning light. It sits at about 20psi and increases rapidly to 40+psi when rpm is lifted above 1000 (at operating temperature) In a built engine, oil viscosity choice is critical if you want the engine to be quiet and not have piston rattle, as racing pistons typically have shorter shirts, and run more liberal clearances than stock pistons. If you run a high viscosity oil like 50 or 60 (never mind the 10w its only for cold winter start anyway) I believe it makes the oil too good to remain inside the bearings (thus the higher pressure) BUT this in turn results in less bore lubrication beneath the pistons, as less oil is flung around by the crank, thus the pistons and bores have less oil film and a higher potential for rattles. Most if not all after market conrods I have seen, have also deleted the small oil squirter hole at the base of the big end bearing, resulting in a drier bore then stock. Every engine will be different depending on specification of parts and clearances, but I have built a few of these by now, and my current engine is the only one which I have managed to get to be 100% as quiet as a unit running of the Ford production line, but the wrong oil choice (too heavy) will make this engine rattle slightly, despite the extreme care taken in choice of clearances. I have lately upped the viscosity slightly by blending a 30 and 50 oil to try to find the optimal viscosity, and this work will continue.
