pip_brendanAKAfrosty
About pip_brendanAKAfrosty
  • Birthday 10/01/1990
    brisbane
  • Interests
    my band, skatebaording, boobs, fast cars, fun and alcohol
2,477 profile views
  1. Hi guys, Need some help please! I have a 2007 BFmk2 FPV Tornado Ute, 6 speed manual. I had my clutch replaced over 18 months ago and since have had problems with the clutch pedal losing its pressure, its current got about 75mm of free play before it begins to engage and moves the clutch, and when I say free play I mean its basically floppy. So now I cant even get my car into gear because the pedal wont move the clutch enough. At first I though it was a slave cylinder issue but it seems to be just something out of place. I do recall hearing about an issue with a spacer needing to be put it when replacing from a standard factory clutch. Has my mechanic forgotten to do this? Has anyone experienced a similar issue?
  2. Happy Birthday pip_brendanAKAfrosty!
  3. Hi guys, Need some guidance ASAP! I have a 2007 BF FPV Tornado Ute 6 speed manual. I have a leaky high pressure power steering pump line and as some of you may know there are 2 different kinds to this part when it comes to buying a replacement. One which has 2 bends at the bottom and one which has 3. Can anyone tell me which I need to get? Thanx!!!
  4. Happy Birthday pip_brendanAKAfrosty!
  5. Happy Birthday pip_brendanAKAfrosty!
  6. Happy Birthday pip_brendanAKAfrosty!
  7. hi, I have a 2007 BFmk2 6 speed FPV tornado. purchased at 99,000kms now having 120,000. whilst driving home from a long trip away in mackay last week, my ute suffered a severe driveline blowout. unfortunately my car is way too low so there was no way I could determine the exact issue right away and after finishing the final stage of my long drive home with the ute making ghastly noises coming from just behind the gearbox, I had it trucked to my mechanic only to find out it as alot worse then I had pictured. apparently the centre bearing rubber had basically disintegrated and the centre bearing and the hanger went long with it leaving only the drive shaft to be held up by the exhaust which copped a brutal beating also. now im left with the expensive issue of getting her back on the road. my mechanic says he can fix it no worries if he can get the parts but apparently its a different (smaller) housing and he cant just buy a centre bearing nor the hanger on its own, despite already welding in plates in the tunnel to mount the new hanger too, where the old bolt holes where sheared out, theres no way im paying $3000+ for a whole new drive shaft setup. is there anyone here who has faced a similar problem or has a solution for me????? for some reason my mechanic says this model was a rarity and standard parts from any other model don't work. im no expert but this sounds like a pretty big f*ck up on fords behalf as I was told the centre bearing had been replaced on this vehicle once before and if its not fixed right this time will happen again and again. I am also told this is not an uncommon story from these utes??? PLEASE HELP???
  8. Happy Birthday pip_brendanAKAfrosty!
  9. ^^^DEVO! fi I can get somebody to drive my ute out there I'lll be keep n so will another mate of mine with a xr8....WOOT WOOOT!
  10. ready lol probs not...I am just qurious as to waht she's pushin
  11. wow count me in on this please!!!
  12. aparently they are bigger holes then that...
  13. ok so my mate just bourght an xr8 ute with a hardlid which has a spoiler on it, he seems to think that its a wankers wing n wants it off, problems is he dosent want 4 little holes in his lid, who has a good DIY solution or dose anyone know where to get some little plugs or anything just through any good ideas at me to I can shut my mate up??? cheers.
