bwhinnen
About bwhinnen
  • Birthday 07/08/1971
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    Hills, hills and more hills = Brisbane
  1. Happy Birthday bwhinnen!
  2. Happy Birthday bwhinnen!
  3. Happy Birthday bwhinnen!
  4. Don't forget to wax your babies after the good polishing you give them! A couple to look at are Autosol and Swissol. Autosol is akin to Meguiars / Mothers in quality, ie better than average and around the same pricing. (Autosol also make polishes as well) Swissol ranges from $100 for a tub to $3 - 4k per tub. I used the Shield (about $160 a tub) and its great for harsh climates like Darwin or the tropics. Cheers Brett
  5. There was no way I'll get it as an option at that price. I'd have to drop the prem brakes or both the prems and the 18's or the hard tonneu cover if I was to pay that amount! The new car's a way off yet (I'm sure the series II will be out by that time ) so just getting my options together at this stage, just keeping the dream alive. Cheers Brett
  6. I rang the dealer today to see if I could option an XR8 bonnet onto the XR6T, I just love the look of the XR8 bulge! Yes it can be done, but at a premium of $2300!! Anyone priced an XR8 bonnet as a spare part yet? Cheers Brett
  7. I own a different car altogether, but a turbo none the less. I've had it for 4 years 105000km and the turbo's been red hot on many ocassions (sustained 200+ runs, done legally on trips from Darwin to Tindal and back). There is no indication of any paint failure or any wiring failure. On my car (WRX) the clutch and brake master cylinders sit just behind the turbo and are plastic and have had no effects either. I can't see the T being much different on both paint quality and wiring quality (after all the Subaru paint is pretty thin). Cheers Brett
  8. Any thoughts on a shot glass? My wife collects them and I think this would be a good addition!
  9. Hey c'mon no fair some of us jap car owners know how to appreciate a car regardless of where its made ! Sash: Are you likely to have piccies of the shot glasses as well when you get the beer glasses? Cheers Brett
  10. Its because the car from factory will generally run too much fuel to ensure that all possibilities are accounted for. Most aftermarket ECU's will lean out most area's the major one being part throttle application where you spend the most time (cruise is generally fairly lean anyway on most modern cars), this is why you will see a difference in economy. As to using more fuel to make a bigger bang, that's not technically correct, different engines will make more power on different air to fuel ratios. On a turbo car the more fuel can have a cooling effect on the exhaust charge (it can also, depending on the timing have a positive effect e.g. anti lag applications and earlier spooling of the turbo via retarded timing and increased fuel usage) which will mean the turbo will not spool as quickly as cooler exhaust gases will generally move slower creating pre-turbo back-pressure, less scaveging of exhaust gases etc (this is just a rough example btw before techincal purists jump all over me). Snappertom, sad to see you move away from the rexie but I think you've made a good choice with the T. I know its where I'll be heading, except with the retention of the rexie as well... Cheers Brett
  11. bwhinnen, Shouldn't you Polish after you wax ? I've Polished after Waxing on my wifes scooby doo and it looks tops Correct me if I've applied it in the wrong sequence. Daniel Polish should go on before the wax. The coat of wax is designed to protect the shine the polish gives the paint (not to mention the paint itself). Cheers Brett
  12. Is this problem happening on cars that have done over a certain mileage? I'm wondering if its part ECU and part mechanical, such as some buildup of crap in the idle stepper or similar? The fault sounds almost like given a certain scenario the ECU is trying to close the stepper motor too quickly and thus it stalls. Does anyone who has had the ECU software upgrade know if it takes longer to settle back to idle than it did before? Cheers Brett
  13. Hey Andrew you forgot a step between the paint prep and the wax, the polish Also instead of the Scratch X which is a mild abrasive is the Paint Cleaner or a Clay Bar, I find the Clay Bar easier to use than either the Paint Cleaner or Scratch X, it gives the paint that wonderful smooth feel, a terry towel cloth should glide across the roof and not stop if the paint is truly clean. The wax is just the protective layer, the polish is what will give you the shine. Another tip that is really good is to finish up with some Meguiars Final Inspection or Quick Detailer when you've finished. Just a note, this is something I do every 6 months or so to my car. Cheers Brett
  14. Just stick with a good quality wax to protect your car. I've had my (yes WRX) car for over 4 years and the paint work is still great (champagne silver). It started with Meguiars Yellow wax and then I ended up using a Swissol wax. Good friend of mine who owns a panel shop in Darwin always said if you want to pi$$ your money up against a wall get it, otherwise invest in some good wax. Now a 3M treatment for the interior would be worth it, specially if you've got rugrats. Cheers Brett
