RHR
Moderating Team
Everything posted by RHR
  1. Good stuff
  2. You can get the pan from ebay. Comes with filter etc. The filter is not part of the metal pan like it is for the plastic pan. It is a little tricky to fit the metal pan with the seperate filter but just take your time when doing so Jet uses Gulf western SYNTRAS and if it wasn't for jets feed back on it I would have never of thought about Gulf Western. Ive done the best part of 2500kms since doing the service, pan install and tranny cooler install and the transmission has been faultless The only thing that you really require to fit the pan is torx bits (similar to hex or allan keys) I used the torx bit with a cordless drill purely due to the sheer number that hold the pan on. Made removing and re fitting the pan much quicker
  3. I want a honey badger. Tough little farker
  4. $$ that is all
  5. Knows how to run a good business with simple no bullsh*t customer service
  6. Same POOR service from the SAME advertisers
  7. Or was it towards a RAP1D or through the RAP1Ds. Im not sure??
  8. Just got the best part of a 600km drive today. Coast to Riverina
  9. Wpmo slicing the side wall of a brand new tyre (tyre now farked) Love throwing money down the sh*tter Trying to tell the moron father In law might pay to remove the cause as per his own advice "prevention is better than a cure" and he won't take his own advice. Bang head farking
  10. Minister for war and finance would allow that
  11. 6 and a half hours overtime on public holiday rates. Cha Ching!!!!
  12. cheers
  13. Is it time for cheers yet?? Cheers
  14. Consider your self lucky. Dealers are very hit and miss when it comes to this. Some say wear and tear and others will replace it no questions asked. I've had both
  15. Yep that might work for what ever reason emails etc dont
  16. Nah I think rukey is waiting for these still. Been a few years now. Some quality advertisers we have here
  17. Well I've done a good 600ks since putting syntrans in my terry turbo and there has been no change in performance. If anything I reckon it shifts better. Could be a bit early to tell but so far so good
  18. Back on topic This bloke converted his g6 to turbo http://www.fordxr6turbo.com/forum/topic/80668-my-stock-g6-to-manual-turbo-build/?hl=%20g6%20%20to%20%20turbo Pretty impressive
  19. Well transmission service, steel pan and cooler install Done!!!! (for the TTG) Didnt end up going with a furious kit or transolutions kit due to joining lines and now that I used an alternative cooler Im glad I did. http://www.ebay.com.au/itm/111149979207?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I had all sorts or trouble removing the transmission lines off the OEM heat exchanger. With OEM exchangers, oil filters, numerous water lines in the area there is simply not enough room IMO. After a lot of swearing and the like I finally managed to remove the coolant lines of the OEM heat exchanger and joined them together with the fittings provided in the kit. The exchanger is still on the side of the block as its impossible to remove (well for me anyway. Might have another crack when its due for a service) Im aware the cooler kit I used states for FG but between the FG cooler and the terry cooler there is no difference other than a slightly different bracket or a third bracket (Dont ask me which one) for a $30 price difference (Terry more expensive) I ended up making a small bracket that attached to the bottom of the cooler (Via the bracket provided) and on to the middle radiator support (Roughly in line with the number plate). So fitted the cooler and lines up yesterday. Its pretty straight forward although I found attaching the new lines to the transmission a little tricky room wise. Probably due to the transfer case drive shaft. One thing that I did find interesting was the plastic OEM lines. On the fittings that connect to the transmission they appear to be the same inner diameter to the new fittings that came with the kit so personally I dont think flow will be an issue. The kit came with everything needed including cable ties. So this morning I wet about "flushing" the fluid (drain, fill run through gears and repeat 3 or so times.... THANKS JET) Probably went through the best part of 10 - 12 litres of Gulf western Syntrans in the process. After the final drain the fluid removed was juuuusssssttt about the same colour as the new fluid so I satisfied that I'd done enough. The old fluid was very dark and now bright red, the colour of syntrans Next was removing the old plastic pan. A cordless drill with a torx bit here is a must. Just took my time here and removed the bolts/screws from the the back of the car to the front. Left all but two bolts/screws in the front (loosened) and was able to tilt the old pan to drain the remaining oil. Once the pan was off I gave the alloy surface a good clean (Carby cleaner on rag then wipe) ensuring that there was no left over gunk. Fitting the new pan was tricky. As the filter is not part of the pan you have to sit the filter on the pan and slowly lift it up into position. It sounds easy but with a gasket also floating around/in the way it definatly makes it more "fun". Got it all bolted/screwed up (thanks again cordless drill) and later tensioned up all the bolts/screws by hand So the final fill began at this point and followed the ZF doc to a degree. I had the car up on stands and whilst on the stands ran it through the gears again and later checked the oil level. Topped it up and all done. After cleaning up took it for a run and all good. The transmission "feels" better the way it shifts, smother if you know what I mean. Stopped and checked under the car and cooler connections. No leaks... HAPPY DAYS. So all in all the entire job took the best part of 7 hours without rushing. This is purely how I did the job and I don't recommend any one take this as the "How to" to do this.
  20. Just don't put it near the icc. Ms700 if memory serves me correctly found out the hard way
  21. Don't mind dirty bird but the pie...meh.....not bad but not great
  22. All but confirmed now. Now to get the accommodation sorted.....
  23. From memory there is a mob in the gong that do wheel fixes
  24. 5am = kids wide awake No sleep in = sad face Moaning is more fitting
