3
bjc last won the day on December 15 2023
bjc had the most liked content!
365 ExcellentAbout bjc
- Birthday 11/03/1978
Contact Methods
Website URL
http://
ICQ
0
Gender
Location
Townsville
Interests
Cars in general, Car Stereo and Horsepower! Home Theatre also and I Enjoy having a chat over coffee...
17,899 profile views
Remove the head and clean it up to see unless you know a way to clear it without removing the head (I wouldn't crank it over regardless). It's another head gasket as well unless you can reuse it being a fire ring? Spray some inox or oil in the cylinder if leaving it otherwise maybe pressurising the cylinder would be easier than the coolant system to see if air enters the coolant or vice versa if you can pressurise the coolant system without killing the radiator. Not sure you could apply enough pressure for either but I'm just spit balling as it's becoming the never ending story...it has been great for the knowledge department but your back, bank account and sanity is what takes the toll!
You need to crack out the mig and weld the front and rear diffs and the transfer case planetary! Edit: flames need more methanol. I take no responsibility for your death or any other living thing on or off the road after the above mods (this includes being airborne in said vehicle)... 😁
That's farked! You're a better man than me wrt setbacks. I'm not driving mine anymore (unless I really have to for appointments) until next year when I can use a spanner as it's just to frustrating for me with its multitude of issues. I'd burn the cunce but the insurance isn't even worth it to me so I'd rather see it turn to dust...that's my relationship with the car anyways! My attitude might change when I can lift more than 2kg and allowed to put my farking arms above my head but that's for later. Keep the good, bad and ugly coming 😂
The Haltech isn't stuck on wot afr for your cruising? I assume it runs a wideband and has CL fuel control. All injectors are firing together for that old school carby style smell lol
Seems like the coatings works for you though... I've seen Steve Morris using whatever brand he has gone to now for the piston skirts (line to line?) and he's happy with it along with what he calls a hard anodising on the crown. The Motoroil Geek and his offsider with whatever they use and now testing coatings on their total seal piston rings.
bjc changed their profile photo
Did you swap the battery to see if that sorted the cutout issue or not pushing your luck and going ahead with the rebuild? Keep the updates coming even the small sh*t as I'm out for the year and this stuff makes me feel better lol.
Yeah I see the hassle of the jet installation. You could just set the injection DC to only be 75% or so at your current full boost (if you did install port injection). Unsure how the Aquamist works but a basic system would be set to 35psi max so by your 26 odd psi tune you'd have 75ish percent injection and with the FAV it does the pulsing instead of the pump in other systems so it should meter correctly? All you need now is to grab a litre of nitro from your nearest hobby store and do some mixology testing lol
Is that with just pre throttle body injection and not port for the meth?
EGT's with a decent duration (drag strip or high speed full throttle on the highway) is where it makes a big difference along with lower intake temps. Fwiw, I always mix ratios by weight not volume. Probably not hugely critical with water/meth injection unlike making RC car nitro mixes but we mixed our water/meth via weight as well... You've probably got a hydrometer though.
I'm interested to see your feedback on the water meth tuning as I've followed it relatively closely for years (pre 2010). I've got a Snow Performance kit but never installed it on the F6X only the BA turbo as a knock buffer. A mate had the same kit (single nozzle) on his FG and with basic mods on 98oct 12.2 ish afr made an easy 380kw with the kit (500cc nozzle I think). 420kw was the limit (stock gt3582r no flapper mod) but with no safeties in place with our basic hobbs switch kit and a daily 380kw was plenty. 3 degrees easily advanced with 6 being probably the limit on a non direct port install but interested to hear your experience Puff...
What Puff said but it's a karnt to get out and you'll think it's welded in as even the c clip is troublesome, gentle violence is the key... For the reg I think I ended up using adjustable pliers with a piece of bike tube around it so it didn't slip and so I didn't crush the reg but as soon as it twisted I got it out no problems.
It was Zane from Maxx Performance that told me years ago (when he first started making the 2 piece 3rd diff bush from hdpe) that the dump pipe just needed a big hammer. I have an FG exhaust manifold but it needs a serious linish or probably a mill if my father inlaws is big enough for the job as it's a fricking banana! Most of this stuff is a pipe dream for me in my current state but hopefully that will change by years end... I have most items for the usual mods except for the dump valve for the exhaust as I don't need a 3.5" even though I'd like a full system
Have you tried a 4" dump pipe from a B or FG series as I've heard they just need a good belting with a hammer for some clearance issues? I went to try the two I've got a few years ago but couldn't get the nuts (or bolts?) undone from the housings so I gave up. My boost was similar to yours with 18 in the mid and around 14 up top, punched out cat though and the usual bung removal otherwise stock exhaust and it sounds like a sh*t diesel truck when idling lol
Unsure what the coolant ID size is (19mm maybe)? I'd just use copper pipe as it's easily flared and bent but that's me. Pretty sure they sell a pipe to connect them and fits to the old mounting locations but unsure of the name...
ZF external cooler install and transmission service - How to
bjc replied to El Andrew's topic in Driveline Workshop
What lowest temp do you lot recommend before raping the ZF? My cold starts are usually 30°C being in NQ but the ZF gets to about 60-65°C quickly and then warm up is slow when cruising around town to get to operating temp of 78°C (thermostat is 82°C)...
