mikeBF2TLS
About mikeBF2TLS
  • Birthday 04/04/1962
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    Canberra
2,461 profile views
  1. Happy Birthday mikeBF2TLS!
  2. Happy Birthday mikeBF2TLS!
  3. Happy Birthday mikeBF2TLS!
  4. Happy Birthday Brock Whelan!
  5. Happy Birthday MY_FORD_2007!
  6. Happy Birthday ipponinoz!
  7. Happy Birthday mikeBF2TLS!
  8. Happy Birthday mikeBF2TLS!
  9. Have just installed Philips 8 spot DRL's on my G6ET. They are road legal in Australia, dim down when parker lights and upwards come on. Photos do not do total justice. They come on automatically however am in the process of using a manual overide switch to turn off when not required. The electrics with the unit will not allow for the lights to be on maximum output at night. They are super bright in daylight. 2 photos were taken with the park light on (& flash went off) consequently the dimmer was working at this time as well.
  10. I've been searching for quality DRL's for quite a while. Invision has now released the Philips range of DRL's used o'seas into Australia. They come with full wiring loom and are OZ compliant. Can order through Autobarn (Try Fyshwick ACT). However if linked up to the parkers I notice that the parking lights seem to stay on in the FG when normal running lights (low & high beam) are on as well. However specs state that the DRLs will dim when normal lights are switched on. Check out this website for full specs and installation guide:- http://www.invisionsales.com/lighting/philips/drl The LED Daylight 8 DRL (as in the brochure) fits perfectly into the G6E lower grill (I've measured) Mine are going in on the 2nd bottom row in the lower grill as far as left and right that you can go. You only need to cut out one of the vertical grill webs on each side to fit in, with 8 spec light slotting exactly into the plastic grill space.
  11. Question, Does any one know if these'Ebay' LED replacement globes, will these also fit into a G6ET? The foglights on the G6ET appear to be smaller than those on the FG6T & FGF6.
  12. Question how much did the Marcello Rims cost? Gather you put the Ford 19" tyres on them or were these seperate? Look fantastic!
