jason426
  1. has any body had a rebuild from the boxstop and what are they like
  2. yeh I have a tranny cooler but I will get a bigger one and did you have to retune for the gearbox
  3. got a xr6t making a rattling noise from the back of engine on the exhaust side and gearbox is acting like it is low on oil slipping.I live in brisbane who would be the best to go to gilroy's or the boxstop. The boxstop is fairly close only a couple of suburbs away as gilroy's is in toowoomba.The car is making 315 rwkw. Gilroy's put extra clutches in and doesn't mod the valve body as the boxstop mods the valve body but doesn't put extra clutches in as I know
  4. hi I went to willowbank yesterday and put bp 98 and my car was missing and pinging down the 1/4 mile also had a surge in third gear so I know the fuel is the reason for pinging. I'm going to change fuel filter and put shell or mobile in it and see how it goes
  5. I'd like to get 300 rwkw or more. I have a tuner getting 3.5 exhaust on saturday, then I'm going to get injectors & a intercooler. I will then go get it tuned
  6. thanks for that info but will I need a surge tank and with the fuel line do I cut it and will hose clamps hold the pressure. Will standard injectors be ok till I buy bigger ones
  7. its a sedan
  8. hi got a bosch fuel pump from aps not sure of the best place to put it and do I need a fuel pressure regulator
  9. hi new to this but I put the capa flash tuner in and it was missing under load from 2500 rpm up upwards change plugs which have .8 gap still doing it . the coils have fine cracks in them could this be the problem and is there any better aftermarket ones
