6onb00st
1 Neutral
1,201 profile views
  1. Does anyone in the western suburbs or surrounding areas have the atomic valvespring removal tool that I could lend as id like to install my new valve springs myself. any help would be greatly appreciate. cheers matt
  2. hi mate I have the 800hp kit plus aps exhaust,injectors,plazmaman surgetank with 044,turbo porting + 8psi flapper. im currently making 350rwkw at 15psi and am hoping for more once I do the valvesprings.
  3. thanks for all your opinions guys think I might go the bilsteins.
  4. hi guys just wanted to get some opinions on shocks im currently due for some new shocks and wanted to get either koni or bilstein I already have lovells springs standard xr ride height and would like some shocks to match. cheers matt
  5. recently had my car tuned and ever since im getting a clunking sound from the left rear of the car. It only seems to do it when turning right could it be a worn cv joint,diff bush or suspension problem any help would be great. cheers matt
  6. I finally got into the 300 club and im glad to be here. Had the car tuned by chris at bluepower and it made 329rw im pretty happy at this power level but will probably want more later on.
  7. im only chasing about 330 rwkw so would just a high flow cat be enough or should I just go a full exhaust system
  8. would you recommend a full exhaust system if so what brand and size would you recommend
  9. recently had my car dyno tuned and was told it had valve float at 14psi mods it has are injectors,plazmaman 800hp kit,fuel pump and surgetank,cooler thermostat im running the standard exhaust though could this be the problem cause I thought bf mk2 have the f6 valve springs so should handle the power any advice would be great cheers matt
  10. thanks for that mate. where exactly is the pollen filter
  11. ive got my 40,000 kilometer service coming up soon and was just wondering what exactly it is I have to service apart from oil and oil filter should I re torque the exhaust manifold bolts. any suggestions would be great cheers matt
  12. its a bf mk2 xr6 turbo 6 speed manual the car is a weapon now I love the sound of the turbo now with the new piping next on the to do list is a new clutch then injectors and a surgetank and pump.
  13. I recently installed a plazmaman 800hp kit to my car I took it into bluepower racing to get the cooler tuned to the car. It made 272.9rwkw everything standard except for cooler and piping it goes like it should from factory and is better on fuel im very pleased next to come will be a new clutch and then injectors. cheers matt
