dragons90
21 Excellent
Contact Methods
  • ICQ
    dragons90
  1. Can you move me up from 41 to 36 QLD Gerard / Elite automotive FG F6 A6 Sedan - Willowbank 10.90@129
  2. My 2011 auto f6 made 275RWKW
  3. I didn't get a emission's test when I got my LA4 mod plate.
  4. Its in the national code of practice for light vehicle construction and modification NCOP 14 which I know is used in QLD. Ether go to a different rwc and tell them it only makes 15% over stock or get a LA4 mod plate.
  5. Only if you change cars do you lose lives not loading tunes into the same car.
  6. That's the centre bearing they use from commodores, I've got a driveline services tail shaft that deletes the rubber coupling but it adds nvh and put more load on the zf. If I had the choice again Id get A single piece carbon fibre shaft, may still end up getting one.
  7. I don't think a black cooler would work on a f6 cause the lower half's exposed.
  8. With the update can you play all song by a artist or do you still have to pick a album?
  9. Nt05r aren't street Legal.
  10. Turbotrana have you tried toyo r888?
  11. Are you have trouble stalling up on the line or chasing reaction time?
  12. do you know if the new exhaust housing you got was a fg one.
  13. Sorry I mean the swirl pot not the regulator, I know that needs to be upgraded.
  14. If you were to run a surge tank and twin 044 returning to the surge tank first with the stock intank, will you still have high fuel pressure problems or will it be fine because you've only got the stock amount of fuel going into the surge.
  15. Creating high exhaust backpressure in the turbo.
