Any one else got any opinions on this? I need to decide by tomorrow what I will be putting in rather be a coopers ( only filter I know of that's e85 comparable and will fit standard fitting) or going a aftermarket max 10micron Like stated in the thread above...
I have asked this before but what fuel filters are people using with e85? I have a bf ute and I know a few people are using the coopers replacement but I can't find enough info on it be comfortable. Ideally I'd like to not have to cut lines etc but if I have to so be it. Thanks, Jay
Not quite that bad freeze the fitting kit can be made for around 120+ wiring.(thermostat housing $25, top hose $25, 8xstuds $40, vacuum fittings $30. It's not a terribly bad rip off
Also I'm making up the studs needed for this installation in stainless if anyone needs some while I'm at it? Exact same as the ones from nizpro only better. Engineering studs 8x38mm
Thermostat housing- W049 Kilkenny castings product (EB 4L) Radiator top hose- 05-0919 gates product (EF 5L bottom hose) Ralph on plaz piping it is connected behind the fog light so the loom can be hidden under the radiator. Aaron that is going to look awesome I'm still deciding whether to paint it or not. Did you buy yours before this sale? Looks like yours is just unpainted and ours is actually 'raw'. Also did you buy that rocker cover setup off Scott?
Aaron are you keeping the 'turbo intercooled'? Ms no hassles it really is pretty easy. I used a impact driver to get the old manifold bolts out as they were f*ckin tight. Do you have access to a right angle drill? If you have read the online instructions there's not much in it
