MJSXR6T
About MJSXR6T
  • Birthday 05/11/1972
    Brisbane
  1. Happy Birthday MJSXR6T!
  2. Happy Birthday MJSXR6T!
  3. Happy Birthday MJSXR6T!
  4. Happy Birthday MJSXR6T!
  5. Happy Birthday MJSXR6T!
  6. Does anyone have exact numbers of turbo sedans and turbo utes that are going to be made? Hopefully they will limit numbers to keep them a bit special. Ordered a sedan in Lightning Strike with auto. Will be sad to see the BA go.
  7. The one I fitted to mine had Sonic Performance on it. It was genuine Earls fittings and filter. When I asked who made the lines, I was told that they are made here in Australia by MTQ. Not sure if you can buy direct, but Lee at RDP supplied it at a good price.Hope this helps.
  8. Below are the dates for the test and tunes. Hope this helps. Cheers Marc 01 Apr 2009 10 Apr 2009 25 Apr 2009 29 Apr 2009 02 May 2009 06 May 2009 13 May 2009 21 May 2009 23 May 2009 27 May 2009 30 May 2009 17 Jun 2009 25 Jun 2009 01 Jul 2009 08 Jul 2009
  9. Hi guys, count me in. Do you normally meet up and drive out as a group or just meet there. Will be great to meet a few members.
  10. Thanks for the info. The BF and FG short is going to cost $2400 from Ford. Can you give me an idea of the price on the phoon motor please. I was going to use this while building up the original with the good gear. To make this swap worthwhile, I am trying to achieve between 350 to 480 rwkw until the other block is finished. Thanks all for the information. Cheers
  11. I looked everywhere and could not find the answer so I have had to post the question. Does anyone know the difference if any between the BF MKII and the FG FPV short motors? Also will the FG FPV short, bolt into a BA MKII with all standard BA parts I.e manifolds, cross pipes, engine mounts etc? What kw should the FG FPV motor handle? Thanks in advance for your replies.
  12. Hi CaRtZ, Just make sure that the C/W and T/W cannot touch the housings at all when dry. If there is clearance there all is good. Cheers
  13. MJSXR6T
    Xr6t O5
    Hi Wilbaz, any good turbo shop can do the job for you. Firstly you need to work out what you are trying to achieve. I had a T04Z comp wheel and 38mm wastegate flapper installed, great top end but laggy as. The standard 35 will handle 450rwhp quite well. I had mine done at MTQ in Brisbane, good job good price and located nationally. Cheers
  14. Just wondering if the FPV intercooler is that much better than the standard XR6T unit and does it bolt directly in. If this is a viable upgrade, does anyone know what they roughly sell for ? Also has anyone done this conversion and how did they find the result? Cheers
  15. Very frustrating!!!!! It wasn't as noticable until I had the mod work done. Has anyone tried replacing the converter? If so did it fix the problem and what converter was used. Cheers
