stevet
  1. I know what you're talking about Peter. Since I had my car played with using VCM the traction control is virtually non existant. When traction is lost the light will flash for a second or two while it tries to control the wheelspin then after that traction control is turned off and the light comes on and cant be turned off until the car is turned off. Weird. I dont know why it does it? When it was stock the traction control would do its job without turning off even in the wet.
  2. Im down south man, Invercargill.
  3. I've found Justin at HDi really good and very helpful. My cars got problems and hes helping out where he can.
  4. Hey guys. Who is a good tuner of turbo falcons in the southisland?? Anyone had good experiences? Prefer if they use VCM or Snyper. Having issue with tuning my car locally and looking at alternatives, someone who has worked on XR6T's and knows them well. Cheers
  5. stevet
    Psi Loss
    Hi guys my car with is currently losing about 5psi between the turbo and the engine. It has an HDi cooler kit and has checked ok for leaks. I understand as a part of a cooler working a cooling air a certain amout of psi is lost but this is too much and I think is causing problems. Also on stock tune it seems to have miss when accelerating hard as the auto changes 1st to 2nd and 3rd to 4th. Maybe that has to do with tourque limiting? As it almost has that feel to it. Any ideas would be great cheers.
  6. I know the question 'Can I run a larger cooler without a tune?' has been asked many a time, and currently that's what im doing. I have a Hdi kit installed and my car running on stock tune while we work through a few issues with the retune. I am taking it very gently when I drive it, but I did push it once and under boost it seemed to make a 'popping' noise from the exhaust and performance was average. As soon as I heard the noise I realised it cant be good and didnt do it again but I just wondered what it was? Is that overboost? popping from the exhaust I thought would have been unburnt fuel in the exhaust? Hope I didnt do any damage, but its happy enough just cruzing around......
  7. So hi afr's means running lean? Would your be able to tell if it was? Perhaps a miss at full throttle?
  8. I bought one and it did bugger all. I think its created more problems than anything else. 20 - 30kw without a tune? I'd like to see them prove it........
  9. It only made 15psi 'freeboosting' where I guess they dissconect the boost solenoid?? and it just boosts without any control or limit. So no that's not the reason. dont know what power it made on that run??
  10. Had car back at tuners starting to get ideas as to what might be going on. Letting the turbo freeboost it only made 15psi, measuring boost at the turbo and then at the motor was showing approx 4 - 5psi less so potentially somewhere between the turbo and the engine could be a leak, controling boost via a boost tap (instead of computer) got rid of the surging issue?!. Those are the things I remember after talking to the tuner. So at this stage we are going to take the front bumper off and check for leaks or anything that could cause a drop in boost pressure. The fact the turbo could only make 15psi MIGHT suggest its not too healthy? Dissapointing since its only got 68km on the clock, and I dont like the sound of the prices to repair these turbos. Could my cat play a part in this??
  11. What you just bought a new one? Could you not have reco'd the old one? Was it just through trial and error you found the problem?
  12. Yeah I think mine makes the same sound benji hard to describe though. Sorta like the sound you hear when you close your mouth and exhale throuh your nose?? Except like you said with a bearing sorta sound lol
  13. hey plugg3r, you get any closer to working out what the problem was?
  14. No offence taken. I dont trust this guy at all, through the information available on this forum I feel I know more about the car than he does. My situation comes down to no other options available in my area, seeing as we arent making progress I have spoken to other tuners but the problem with that is it's a days drive to take it to someone who I would say is competent with the vehicle and has the equipment and know how to deliver a good result.
  15. Havent got the problem resolved at this stage.....
