xrturbomatty
1 Neutral
  1. Hey does anyone know where I can get a new rubber boot for the middle cv joint (just behind center bearing) on my ba xr6t utes tailshaft as mine has split the rubber cheers
  2. Hey go to this site it has step by step info and pics http://trueblueford.com/technical/4speedAUTOservice.html
  3. Hey I was goin to be happy with anything over 300. I bought the box already built and it come with the 3grand stally and the car is running 15psi. I'll have to buy a set of mt,s and head out to willowbank and see what I can run cheers guys
  4. hey guys finally made it 302.3kw big thanks to Steve and all the guys at elite automotive that made it happen couldn't be happier. ba xr6 turbo ute built 4 speed auto with 3000rpm stallie and b&m transcooler Seimens Deka 60lb injectors walbro intank fuel pump rapids v3.5 kit nizpro valve springs xforce 4inch dump into 3.5inch system 12psi actuator and ported exhaust housing with 38mm flapper
  5. Hey my ba used to stall when I came to a stop some times turned out to be the throttle position sensor I think u can reset it to by pushing the accelerator in and kicking the car over for 10 seconds
  6. awesome hope all goes well was thinking bout a surge tank but dont have the cash right now ill just keep the fuel above half and hopefully all will be good cheers fellas
  7. Hey guys going for a tune Tuesday wondering what figures I should expect mods are ba xr6 turbo ute standard bottom end built 4 speed auto with 3000rpm stallie and b&m transcooler Seimens Deka 60lb injectors walbro intank fuel pump rapids v3.5 kit nizpro valve springs xforce 4inch dump 3.5inch cat into twin 2.5inch system 12psi actuator and ported exhaust housing with 38mm flapper also what should I ask for with the auto just the firm the shifts up?
  8. hey not sure about a fg but on my ba there is a bung on the passenger side at the bottom of the radiator. I normally fill with distilled water and run it through the system empty it and do it again and make sure your heater is on so it runs through the whole system. I think its about 10 liters of coolant and I just use a pre mixed nulon coolant seems ok. supercheap has distilled water for cheap hope this helps cheers
  9. hey got the box in shifts awesome just need a retune now cheers
  10. hey mate already got a nice big b&m transcooler with a fan on it thanks for the help anyways
  11. thanks guys will take it really easy till I retune gonna go to elite auto they know what there doing.
  12. hey im getting a built 4 speed and 3000rpm stallie fitted tomorrow is it still possible to drive the car without a retune with the bigger stallie cheers
