RowdyBurns
Everything posted by RowdyBurns
  1. Just pick up the phone and ring around, you'll soon work out what is reasonable and what isn't.
  2. I'll grab them off ya, I'm in Brisbane.
  3. Thanks for the reply dude, I've got a ute so rears need to be big. Plan is 19x9.5 (or 8.5 undecided yet) +25 up front and 19x10.5 +22 in the rear.
  4. If it's a full system, which I assume it would be for that price, you will need to have it tuned. Do you have any other mods? I can't comment if that's a good price or not, but if you don't have any other mods IMO you would be better spending that money elsewhere.
  5. I am looking at a set of these in 19. Before I jump in, should I run hub centric rings? or will it be fine without? Any other issues I should be aware of fitting Jap wheels to a falcon?
  6. I've used 3 gauges pods and never secured the gauges in any of them. As Redskin said if the fit is tight it will be fine.
  7. HAHAHAHA sounds like they are getting desperate. Are they going after 5years of overdues?
  8. Woah blockbuster still exists?
  9. This place will fix it. www.aslautomedia.com.au
  10. 1600kg or 2300kg options. 1600kg - flat tongue 2300kg - hitch (square) comes with load leveling kit. No change to leaf springs unless you get the 1-tonne ute option. No factory option or standard transcooler on ZF, uses the ever reliable heat exhanger. Pussy has been pulled on a bus before, it wasn't good pussy, but it was bus pussy so don't write the bus off completely.
  11. That sounds insane! Nice work.
  12. I had the creak in my BF ute, tightened the nuts on the front of the leaf spring where it meets the chassis and tt went away for a while. Then came back. If it's the same issue I sorted it by putting a washer under the nut and tightened it up with a rattle gun, never creaked again. There's a thread around somewhere about it. Edit: here it is http://www.fordxr6turbo.com/forum/topic/47338-rear-end-creak/
  13. HELL YES!
  14. I bought mine from Ford spares for $200. It's pretty basic, just a siren and a bonnet sensor, but it makes that cool beep that annoys people.
  15. They just called and approved the claim. Goes in next week. If they f*ck it up they can do it again.
  16. ^^ HAHAHAHAHAHAHAHAHA P.S - That's the alarm arming and disarming.
  17. The most annoying part is wanting to take the flaps off and being left with no paint on the outlines of where they were, If it was just the skirt I probably wouldn't care, but the wear marks go up the side of the tub.
  18. That is awesome.
  19. Haven't heard this in years, appears on MAX yesterday and now here. Nice choice haha.
  20. Morning all. Pretty miserable here hey.
  21. Dropped my ute off to Ford this morning for them to check it out, I suspect they will deny the claim. The service guy didn't even want to try it, he said the flaps are loose (haha) and basically not their problem. I had to push him just to get him to put it to Ford.
  22. True that. Funny thing is just before this happened it actually felt stronger and easier to use. Then this. People look at me like I'm a moron when I wind the window down, open the door with the handle, close window. Especially if the door accidentally clicks shut again.
  23. f*ck.
  24. Knocked back a few this arvo?
  25. Morning *yawn*
