flenoxrT
    brisbane
  1. it think it has a lot to do with the tune,some cars will make 330-360rwkw with a stock motor while others will not even get close to 300rwkw, I know of one that threw a rod out and it only had 270rwkw.
  2. and also how do I get a picturte up on my profile
  3. can someone tell me if my dyno sheet is attached to my reply if not can you tell me how to do it please
  4. yes they are very lumpy, the sound puts a lot of v8's to shame its great
  5. hi I managed to dig up my old dyno graph, the curve is not that flash due to the actuator but its not to bad.my mods include:full atomic motor with bigger cams upgraded oil pump and balancer,nizpro plenum and intercooler setup,42pound bosch injectors walbro external fuel pump, battery relocated to boot,flash tuner heavy duty clutch(exedy I think?) x-force full stainless exhaust with 4 inch dump 3 1/2 inch cat then dual 2 1/2 inch and I think that is about it.
  6. hi I had my car tuned at power torque engines, it made 324rwkw and 790nm at 12psi with the stock actuator playing up.the car would only hold 6psi until 5500rpm then it would make the rest so I think that would have hurt the power a bit, it still made 300rwkw at 8.5psi which I have been told is pretty good.it has a new actuator now but I have not hade it tuned yet, they are going to pump about 18psi to 20psi into it so I am hoping for some good numbers.
