Vevapower
    10
Everything posted by Vevapower
  1. Had a mate ring me last week while he was there picking up a cooler tell me.
  2. How did they test it I'd be asking!
  3. Heard plaz will back their 1000 hp over the pw3 and if pw3 makes more power and cools better they'll pay for both coolers and let you choose which one you want to keep. I might take em up on this challenge.
  4. What's your temp rise from start of run to top with your rapid cooler mate?
  5. Unless the track is in perfect prep (so really only ANDRA events like T&T and FTF) your going to struggle to net consistent sub 2 sec 60'fts on street tyres. My best effort on a street tyre (245/40/18) was at such an event and I was able to net a 1.738 Failing a good prepped track you'll need the following:- Built Tail shaft MT 275/40/17 radials ( or similar) 8 - 10 psi of boost Now I found the best method of launching was letting the car tell you so, what I mean by this is that you build your stall on the footbrake and you'll 1st start to hear the spool and then once the car feel like it about to move or actually does start to move this is when you go. If you use this method I assure you, you will need 1.6's or lower but in saying that you'll need to make sure you've also willing for something to break. Practice and patience is the key here, you may fell like your stalling for ages when in fact your only stalling for 2 - 3 secs. Build your stall slowly and for as long as it takes to get either your desired boost or my method of waiting for the car to slightly move. Good luck!
  6. http://www.exedyusa.com/race_clutch/6r80_6hp26_performance_transmission_kits.php
  7. I was sitting in the water for my 1st run and rain came. And cause I'd promised wife I'd be home by 9 unfortunately it was curtains for me. F**K
  8. Spoilt for choice for T3 big hp turbo's these days bud! 4 x 600+ rwkw turbos already avail!
  9. Buy ET radials for street racing, problem solved! And don't street race it's illegal! Put some 18's back on and you have a few ET street options that will make you feel like you car has lost power!
  10. Yeah that's weird Joe (CMS) was able to get as low as 14 psi with one he did recently. Just really strange knowing that it cracks at 12 - 13 on the bench. They can get less then 21 in mine but then again I do have a 26psi actuator! ha ha
  11. Is that 20 degree's from the Plaz bottom to top of run???? Wow.... well better start stocking up on your PW3 coolers Kev as they are gunna run out the door like hot cakes now. 30+ rwkws and 10 degrees min temp drop..... So much win!
  12. <br /><br />For sure mate. ANGLE will bring along the initiation kit.
  13. Ok Gas confirmed this morning that they have typoed on their website and should have said 62mm wheel not 68 mm wheel as in the tech specs for the 6235.
  14. I'm guessing George will make around 460 maybe a tad over!
  15. Is that vava legit? <br /><br />So there might be a vava and a veva there at the same time?
  16. Yeah seems weird. Though 2 other non ford turbo experts I know also confirmed it.
  17. Strange how the 6235 has a bigger turbine wheel then both the 6466 and the 6766!
  18. Thought you'd like that Georgey boy!
  19. Geez that's 3.5 k in tunes right there!
