Vevapower
    10
Everything posted by Vevapower
  1. Yeah might just have your silvia now. Been a journey.
  2. I'll update list on Monday. Well done Josh and welcome to the club. Seems 9's are the new 10's.
  3. Keen to know more about this turbo of yours.
  4. Yeah was told that when box came back from Perth some 1000ks later it started to play up and flare badly. CMS refreshed it and got it going again but not to sure that that spec box would be up to the new power that's being thrown at it.
  5. Nice one mate and congrats on that new found power, a 9 sec car right there! When you say custom Precision what does that actually mean? Surely it's just a 6466 or 6766 right?
  6. Nice one mate. Is that Kev's old car by any chance?
  7. Welcome to the club! Now go and run a 9 already. Is 27 psi just the start of the TK's efficiency range?
  8. Best thing about trying to do a burnout with TC on is that you wont do it again!
  9. I wrote this out a couple of years back and most of it still rings true! But yeah most of it has been covered off by Boganspeed earlier. I don;t mind kicking off. ZF 6 speed drag racing my experiences/tips. 1st outing Things you'll need to do prior. Make sure you take any loose items out of the car Make sure you take a jumper for cooler months (beenie too if Sydney or Mel) Make sure you have a long sleeve shirt Make sure you have over half a tank or at least a 1/3 if you have a surge set up Make sure you take a Tyre pressure gauge ($10 from Supacheap) . Make sure you take helmet that complies to ANDRA AS/NZS1698 under 10 years old Make sure you have an Andra license if you feel your car will dip into the 11's (WSID no longer has this rule and other tracks may have adopted this by now) best to check with the local strip. When your there. Best to arrive early to avoid being not let in and long cues through scrutineering If it's you 1st time tell the desk it is don't lie (they will usually give you an FTXXX number which also alerts the marshals that it's your 1st time and they will be a bit more patient with you/ help you. Park up in your respective lane and open your bonnet, good to get engine temp/bay temps down prior to the run. Take notice of which lane goes before you and (remember some unique or standout cars) this way if your watching or away from your car you'll know you better hurry back to your car. Time to go Tyre pressures I found 22 - 24 in street tyre worked best (but trial an error here guys) and MT's 17 - 18 NItto NT05r's 22 Make sure you bonnet is fully locked down (some people just let it pop to cool and forget to push it back down) Move as instructed to the designated lane. If you don't want to do a burnout drive around the water If you intend to do a burnout make sure you traction control is OFF If your doing a burnout just Drive for first timers is fine or Manual if you know what your doing. Street tyre burnouts only need to be a few seconds start in the water and slower come off the brake and dry the off in the dry surface for a second or two. MT's burnout maybe pull 3 gears in the water (power dependent 2 gears if under 300 kws) and slower roll out and screech up slowy approach the stage if your a first timer watch both the tree and the marshal as he will wave you up. Bring the 1st light on (pre stage) then bump forward (slowly roll) until the second (bottom light comes on - full stage) Now your ready to go. First timers you might just want to watch the lights come down to green and the simply off brake and mash pedal. Stalling up is the better method but does take practice and is dependent on a few things like tail haft spec, stall converter etc... I found 2200ish rpm to be a good starting point for stalling. I would bring up the stall gently and as I reached the designated rpm simply swap from brake to go pedal. If you a first timer best to start with DRIVE Manual is a bit trickier but ultimately quicker. If manual I found pulling gears at 5500 to be about the best speak to your tuner to further refine this but the it best to pull it 500 rpm under the desired point due to human and mechanical lag. Now your humming make sure you keep it pinned he whole way (unless you feel or hear an issue then jump off right away) trying to be WOT slightly past the 400 meter mark. Now on the brake 2/3rs you don't want to be mashing on the brakes at over 200kms. Slow down to around 50 - 60 and then easy does it back along the return road. Make sure if its at night you turn your lights back OFF Collect your ticket and park back up in your lane pop bonnet. Repeat. Other stuff. It helps to go with someone that has a fair idea about these cars and they will be able to help you a lot in things you might forget about or habits you might have. Also they can help you interpret your time slip and tell you places where you might be able to improve or better still advise you on what limit you may only be able to reach on the night. Talk to other Turbo barra guys while your there and swap notes if amazing how much info you'll gain quickly if you do this. And most of all have fun. Warning DRAG RACING IS ADDICTIVE and EXPENSIVE.
  10. 9's 1 WA XFT / XFT A6 F6E FG Sedan Motorplex 9.42 @ 148 RC 2 VIC Steve / Nizpro A6 FG XR6T Sedan - Calder Park 9.46 @ 147 3 NSW Scottm / CV Performance TH400 XR6T FG Sedan - WSID 9.80 @ 145 4 NSW Vevapower / CMS A6 FG XR6T Sedan - WSID 9.95 @ 140 5 VIC FG310 / Nizpro FG F6 A6 Sedan - Heathcote 9.98 @ 143 10's 6 SA Simon / Morpowa A6 FG F6 sedan / A.I.R. 10.05 @ 135 7 W.A Josh J / Monster Torque A6 FG F6 Sedan - Moptorplex 10.06 @ 138 8 QLD XR2DY4 / 6Boost-FPT C4 FG XR6T Sedan - Willowbank 10.08 @ 128 9 SA Paul.S / Nizpro A6 FG XR6t ute / A.I.R 10.36 @ 135 10 VIC EJZ747 / Springy Motors Power Glide XR6T sedan 10.39 @ 136 11 VIC Shanarp / Dyno-Mite A6 FG XR6T Sedan - 10.40 @ 136 12 NSW Yonuis / Autotech A6 FG XR6T Sedan - WSID 10.42 @ 137 13 VIC Vele trajkovskI / Nizpro A6 FG F6 Sedan - Calder 10.45 @ 128 14 WA Tinyplums / monsta toruque A6 FG F6 Ute - Motorplex 10.49 @ 139 15 VIC Nizpro / Nizpro A6 FG F6 Sedan - Calendar Park 10.50 @ 139 16 VIC SSG002 / Nizpro A6 FG F6 Sedan – Heathcote 10.53 @ 137 17 WA Josh J/ Monsta Torque A6 FG F6 Ute - Motorplex 10.53 @ 133 18 NSW Miguel / CMS A6 FG F6 Sedan - WSID 10.56 @ 138 19 WA Handrl / XFT A6 XR6 Sedan - Motoplex 10.57 @ 134 20 WA Marcus / XFT A6 FG XR6T Sedan - Motoplex 10.61 @ 131 21 NSW 10SECN / Autotech A6 FG XR6T Sedan - WSID 10.66 @ 131 22 Kathy / XFT A6 FG F6 sedan - Motoplex 10.67 @ 131 23 VIC Dave / Nizpro A6 FG F6 Sedan - Calendar Park 10.75 @ 129 24 VIC FSIX / Autotech Engineering A6 FG XR6 Ute - HPR 10.77 @ 133 25 VIC Freaky / Nizpro A6 FG XR6T Ute - Calder Park 10.78 @ 132 26 NSW Ford no1 / Autotech A6 FG F6 Sedan - WSID 10.84 @ 132 27 VIC Simon G / Nizpro A6 FG F6 Ute - Calder Park 10.85 @ 132 28 QLD Paul@Elite / Elite Automotive A6 FG F6 Sedan - Willowbank 10.86 @ 131 29 NSW natsxr6 / Autrotech A6 FG XR6T Sedan - WSID 10.87 @ 125 SMALL TURBO Record 30 VIC G6E-PSI /Rajab Racing A6 FG G6ET Sedan - Calder 10.88 @ 127 31 QLD Brett Deller / R.D.P. A6 FG F6 Sedan - Willowbank 10.89 @ 126 32 NSW RynoF6 / CMS A6 FG F6 Sedan - WSID 10.91 @ 131 33 NSW Scott / CMS A6 FG F6 Sedan – WSID 10.93 @ 127 34 SA JETSNOT/ Henirich Performance A6 FG F6 Sedan - A.I.R 10.97 @ 132 35 W.A Tim T/Monsta Torque A6 FG XR6T Sedan - Motoplex 10.98 @ 131 36 VIC Frank / Nizpro A6 FG F6 Sedan - Calder Park 10.98 @ 128 37 QLD Lee RDP / R.D.P A6 FG XR6T Sedan - Willowbank 10.99 @ 126 11's 38 QLD Gerard / Elite Automotive A6 FG F6 Sedan - Willowbank 11.00 @ 128 39 NSW ScottM / Tuff Tune A6 FG F6 WSID Sedan - 11.01 @ 129 40 VIC James333 / Dyno-mite A6 FG F6 Sedan - Calder Park 11.02 @124 41 ACT - Dylan / ESP Racing XR6T Sedan - WSID 11.04 @ 124 42 VIC Jack / Bluepower A6 G6ET Sedan - Calder 11.11 @ 124 43 VIC HINRG / Nizpro A6 XR6T Sedan – Heathcote 11.12 @ 128 44 WA Walsey / UNKNOWN FG A6 Sedan - Motorplex 11.16 @ 126 45 SA Jarrad / Morpowa A6 FG2 XR6T Sedan / A.I.R. 11.18 @ 131 46 NSW KEVPW /CMS A6 FG F6 Sedan - WSID 11.20 @ 133 47 SA Jon / Morpowa A6 FG G6ET sedan / A.I.R. 11.20 @ 127 48 NSW sct911 / CMS A6 FG XR6T Sedan - WSID 11.23 @ 125 ST 49 WA Ernie / Monsta Torque/A6/XR50 Ute - Motorplex 11.24 @ 130 50 NSW LU82 /CMS A6 XR6T Sedan - WSID 11.279 @ 123 ST VIC 17 cars NSW 15 cars WA 10 cars SA 4 cars QLD 5 Cars ACT 1 car
  11. Thanks Dan and yes I think your right. Converter is dying we think so quick freshen and a couple of other tweeks plus good track an who knows maybe a mid 9!
  12. 9's 1 WA XFT / XFT A6 F6E FG Sedan Motorplex 9.42 @ 148 RC 2 VIC Steve / Nizpro A6 FG XR6T Sedan - Calder Park 9.46 @ 147 3 NSW Scottm / CV Performance TH400 XR6T FG Sedan - WSID 9.80 @ 145 4 NSW Vevapower / CMS A6 FG XR6T Sedan - WSID 9.95 @ 140 5 VIC FG310 / Nizpro FG F6 A6 Sedan - Heathcote 9.98 @ 143 10's 6 SA Simon / Morpowa A6 FG F6 sedan / A.I.R. 10.05 @ 135 7 W.A Josh J / Monster Torque A6 FG F6 Sedan - Moptorplex 10.06 @ 138 8 QLD XR2DY4 / 6Boost-FPT C4 FG XR6T Sedan - Willowbank 10.08 @ 128 9 SA Paul.S / Nizpro A6 FG XR6t ute / A.I.R 10.36 @ 135 10 VIC EJZ747 / Springy Motors Power Glide XR6T sedan 10.39 @ 136 11 VIC Shanarp / Dyno-Mite A6 FG XR6T Sedan - 10.40 @ 136 12 NSW Yonuis / Autotech A6 FG XR6T Sedan - WSID 10.42 @ 137 13 VIC Vele trajkovskI / Nizpro A6 FG F6 Sedan - Calder 10.45 @ 128 14 WA Tinyplums / monsta toruque A6 FG F6 Ute - Motorplex 10.49 @ 139 15 VIC Nizpro / Nizpro A6 FG F6 Sedan - Calendar Park 10.50 @ 139 16 VIC SSG002 / Nizpro A6 FG F6 Sedan – Heathcote 10.53 @ 137 17 WA Josh J/ Monsta Torque A6 FG F6 Ute - Motorplex 10.53 @ 133 18 NSW Miguel / CMS A6 FG F6 Sedan - WSID 10.56 @ 138 19 WA Handrl / XFT A6 XR6 Sedan - Motoplex 10.57 @ 134 20 WA Marcus / XFT A6 FG XR6T Sedan - Motoplex 10.61 @ 131 21 NSW 10SECN / Autotech A6 FG XR6T Sedan - WSID 10.66 @ 131 22 Kathy / XFT A6 FG F6 sedan - Motoplex 10.67 @ 131 23 VIC Dave / Nizpro A6 FG F6 Sedan - Calendar Park 10.75 @ 129 24 VIC FSIX / Autotech Engineering A6 FG XR6 Ute - HPR 10.77 @ 133 25 VIC Freaky / Nizpro A6 FG XR6T Ute - Calder Park 10.78 @ 132 26 NSW Ford no1 / Autotech A6 FG F6 Sedan - WSID 10.84 @ 132 27 VIC Simon G / Nizpro A6 FG F6 Ute - Calder Park 10.85 @ 132 28 QLD Paul@Elite / Elite Automotive A6 FG F6 Sedan - Willowbank 10.86 @ 131 29 NSW natsxr6 / Autrotech A6 FG XR6T Sedan - WSID 10.87 @ 125 SMALL TURBO Record 30 VIC G6E-PSI /Rajab Racing A6 FG G6ET Sedan - Calder 10.88 @ 127 31 QLD Brett Deller / R.D.P. A6 FG F6 Sedan - Willowbank 10.89 @ 126 32 NSW RynoF6 / CMS A6 FG F6 Sedan - WSID 10.91 @ 131 33 NSW Scott / CMS A6 FG F6 Sedan – WSID 10.93 @ 127 34 SA JETSNOT/ Henirich Performance A6 FG F6 Sedan - A.I.R 10.97 @ 132 35 W.A Tim T/Monsta Torque A6 FG XR6T Sedan - Motoplex 10.98 @ 131 36 VIC Frank / Nizpro A6 FG F6 Sedan - Calder Park 10.98 @ 128 37 QLD Lee RDP / R.D.P A6 FG XR6T Sedan - Willowbank 10.99 @ 126 11's 38 QLD Gerard / Elite Automotive A6 FG F6 Sedan - Willowbank 11.00 @ 128 39 NSW ScottM / Tuff Tune A6 FG F6 WSID Sedan - 11.01 @ 129 40 VIC James333 / Dyno-mite A6 FG F6 Sedan - Calder Park 11.02 @124 41 ACT - Dylan / ESP Racing XR6T Sedan - WSID 11.04 @ 124 42 VIC Jack / Bluepower A6 G6ET Sedan - Calder 11.11 @ 124 43 VIC HINRG / Nizpro A6 XR6T Sedan – Heathcote 11.12 @ 128 44 WA Walsey / UNKNOWN FG A6 Sedan - Motorplex 11.16 @ 126 45 SA Jarrad / Morpowa A6 FG2 XR6T Sedan / A.I.R. 11.18 @ 131 46 NSW KEVPW /CMS A6 FG F6 Sedan - WSID 11.20 @ 133 47 SA Jon / Morpowa A6 FG G6ET sedan / A.I.R. 11.20 @ 127 48 NSW sct911 / CMS A6 FG XR6T Sedan - WSID 11.23 @ 125 ST 49 WA Ernie / Monsta Torque/A6/XR50 Ute - Motorplex 11.24 @ 130 50 NSW LU82 /CMS A6 XR6T Sedan - WSID 11.279 @ 123 ST VIC 17 cars NSW 15 cars WA 10 cars SA 4 cars QLD 5 Cars ACT 1 car
  13. Thanks Marky. Without your continued support and boost encouragement none of this would have been possible!
  14. Thanks mate. Yeah you only need 499 rwkws to do a 9 wheres all the haters now!
  15. OK yeah my bad I shouldn't of rushed it! 9's 1 WA XFT / XFT A6 F6E FG Sedan Motorplex 9.42 @ 148 RC 2 VIC Steve/Nizpro A6 FG XR6T Sedan - Calder Park 9.46 @ 147 3 NSW Scottm/CV Performance TH400 XR6T FG Sedan - WSID 9.80 @ 145 4 VIC FG310/Nizpro FG F6 A6 Sedan - Heathcote 9.98 @ 143 10's 5 NSW Vevapower/CMS A6 FG XR6T Sedan - WSID 10.03 @ 142 6 SA Simon / Morpowa A6 FG F6 sedan / A.I.R. 10.05 @ 135 7 W.A Josh J/ Monster Torque A6 FG F6 Sedan - Moptorplex 10.06 @ 138 8 QLD XR2DY4/6Boost-FPT C4 FG XR6T Sedan - Willowbank 10.08 @ 128 9 SA Paul.S / Nizpro A6 FG XR6t ute / A.I.R 10.36 @ 135 10 VIC EJZ747/Springy Motors Power Glide XR6T sedan 10.39 @ 136 11 VIC Shanarp/Dyno-Mite A6 FG XR6T Sedan - 10.40 @ 136 12 NSW Yonuis/Autotech A6 FG XR6T Sedan - WSID 10.42 @ 137 13 VIC Vele trajkovski/Nizpro A6 FG F6 Sedan - Calder 10.45 @ 128 14 WA Tinyplums/monsta toruque A6 FG F6 Ute - Motorplex 10.49 @ 139 15 VIC Nizpro/Nizpro A6 FG F6 Sedan - Calendar Park 10.50 @ 139 16 VIC SSG002/Nizpro A6 FG F6 Sedan – Heathcote 10.53 @ 137 17 WA Josh J/ Monsta Torque A6 FG F6 Ute - Motorplex 10.53 @ 133 18 NSW Miguel/CMS A6 FG F6 Sedan - WSID 10.56 @ 138 19 WA Handrl / XFT A6 XR6 Sedan - Motoplex 10.57 @ 134 20 WA Marcus/XFT A6 FG XR6T Sedan - Motoplex 10.61 @ 131 21 NSW 10SECN/Autotech A6 FG XR6T Sedan - WSID 10.66 @ 131 22 Kathy/XFT A6 FG F6 sedan - Motoplex 10.67 @ 131 23 VIC Dave /Nizpro A6 FG F6 Sedan - Calendar Park 10.75 @ 129 24 VIC FSIX/Autotech Engineering A6 FG XR6 Ute - HPR 10.77 @ 133 25 VIC Freaky/Nizpro A6 FG XR6T Ute - Calder Park 10.78 @ 132 26 NSW Ford no1/Autotech A6 FG F6 Sedan - WSID 10.84 @ 132 27 VIC Simon G/Nizpro A6 FG F6 Ute - Calder Park 10.85 @ 132 28 QLD Paul@Elite/Elite Automotive A6 FG F6 Sedan - Willowbank 10.86 @ 131 29 NSW natsxr6 / Autrotech A6 FG XR6T Sedan - WSID 10.87 @ 125 SMALL TURBO Record 30 VIC G6E-PSI /Rajab Racing A6 FG G6ET Sedan - Calder 10.88 @ 127 31 QLD Brett Deller/R.D.P. A6 FG F6 Sedan - Willowbank 10.89 @ 126 32 NSW RynoF6 / CMS A6 FG F6 Sedan - WSID 10.91 @ 131 33 NSW Scott/CMS A6 FG F6 Sedan – WSID 10.93 @ 127 34 SA JETSNOT/ Henirich Performance A6 FG F6 Sedan - A.I.R 10.97 @ 132 35 W.A Tim T/Monsta Torque A6 FG XR6T Sedan - Motoplex 10.98 @ 131 36 VIC Frank/Nizpro A6 FG F6 Sedan - Calder Park 10.98 @ 128 37 QLD Lee RDP/R.D.P A6 FG XR6T Sedan - Willowbank 10.99 @ 126 11's 38 QLD Gerard/Elite Automotive A6 FG F6 Sedan - Willowbank 11.00 @ 128 39 NSW ScottM / Tuff Tune A6 FG F6 WSID Sedan - 11.01 @ 129 40 VIC James333/Dyno-mite A6 FG F6 Sedan - Calder Park 11.02 @124 41 ACT - Dylan/ESP Racing XR6T Sedan - WSID 11.04 @ 124 42 VIC Jack/Bluepower A6 G6ET Sedan - Calder 11.11 @ 124 43 VIC HINRG/Nizpro A6 XR6T Sedan – Heathcote 11.12 @ 128 44 WA Walsey / UNKNOWN FG A6 Sedan - Motorplex 11.16 @ 126 45 SA Jarrad / Morpowa A6 FG2 XR6T Sedan / A.I.R. 11.18 @ 131 46 NSW KEVPW /CMS A6 FG F6 Sedan - WSID 11.20 @ 133 47 SA Jon / Morpowa A6 FG G6ET sedan / A.I.R. 11.20 @ 127 48 NSW sct911 / CMS A6 FG XR6T Sedan - WSID 11.23 @ 125 ST 49 WA Ernie/Monsta Torque/A6/XR50 Ute - Motorplex 11.24 @ 130 50 NSW LU82 /CMS A6 XR6T Sedan - WSID 11.279 @ 123 ST VIC 17 cars NSW 15 cars WA 10 cars SA 4 cars QLD 5 Cars ACT 1 car
  16. 9's 1 WA XFT / XFT A6 F6E FG Sedan Motorplex 9.42 @ 148 RC 2 VIC Steve/Nizpro A6 FG XR6T Sedan - Calder Park 9.46 @ 147 3 NSW Scottm/CV Performance TH400 XR6T FG Sedan - WSID 9.80 @ 145 4 VIC FG310/Nizpro FG F6 A6 Sedan - Heathcote 9.98 @ 143 10's 5 NSW Vevapower/CMS A6 FG XR6T Sedan - WSID 10.03 @ 142 6 SA Simon / Morpowa A6 FG F6 sedan / A.I.R. 10.05 @ 135 7 W.A Josh J/ Monster Torque A6 FG F6 Sedan - Moptorplex 10.06 @ 138 8 QLD XR2DY4/6Boost-FPT C4 FG XR6T Sedan - Willowbank 10.08 @ 128 9 SA Paul.S / Nizpro A6 FG XR6t ute / A.I.R 10.36 @ 135 10 VIC EJZ747/Springy Motors Power Glide XR6T sedan 10.39 @ 136 11 VIC Shanarp/Dyno-Mite A6 FG XR6T Sedan - 10.40 @ 136 12 NSW Yonuis/Autotech A6 FG XR6T Sedan - WSID 10.42 @ 137 13 VIC Vele trajkovski/Nizpro A6 FG F6 Sedan - Calder 10.45 @ 128 14 WA Tinyplums/monsta toruque A6 FG F6 Ute - Motorplex 10.49 @ 139 15 VIC Nizpro/Nizpro A6 FG F6 Sedan - Calendar Park 10.50 @ 139 16 VIC SSG002/Nizpro A6 FG F6 Sedan – Heathcote 10.53 @ 137 17 WA Josh J/ Monsta Torque A6 FG F6 Ute - Motorplex 10.53 @ 133 18 NSW Miguel/CMS A6 FG F6 Sedan - WSID 10.56 @ 138 19 WA Handrl / XFT A6 XR6 Sedan - Motoplex 10.57 @ 134 20 WA Marcus/XFT A6 FG XR6T Sedan - Motoplex 10.61 @ 131 21 NSW 10SECN/Autotech A6 FG XR6T Sedan - WSID 10.66 @ 131 22 Kathy/XFT A6 FG F6 sedan - Motoplex 10.67 @ 131 23 VIC Dave /Nizpro A6 FG F6 Sedan - Calendar Park 10.75 @ 129 24 VIC FSIX/Autotech Engineering A6 FG XR6 Ute - HPR 10.77 @ 133 25 VIC Freaky/Nizpro A6 FG XR6T Ute - Calder Park 10.78 @ 132 26 NSW Ford no1/Autotech A6 FG F6 Sedan - WSID 10.84 @ 132 27 VIC Simon G/Nizpro A6 FG F6 Ute - Calder Park 10.85 @ 132 28 QLD Paul@Elite/Elite Automotive A6 FG F6 Sedan - Willowbank 10.86 @ 131 29 NSW natsxr6 / Autrotech A6 FG XR6T Sedan - WSID 10.87 @ 125 SMALL TURBO Record 30 VIC G6E-PSI /Rajab Racing A6 FG G6ET Sedan - Calder 10.88 @ 127 31 QLD Brett Deller/R.D.P. A6 FG F6 Sedan - Willowbank 10.89 @ 126 32 NSW RynoF6 / CMS A6 FG F6 Sedan - WSID 10.91 @ 131 33 NSW Scott/CMS A6 FG F6 Sedan – WSID 10.93 @ 127 34 SA JETSNOT/ Henirich Performance A6 FG F6 Sedan - A.I.R 10.97 @ 132 35 W.A Tim T/Monsta Torque A6 FG XR6T Sedan - Motoplex 10.98 @ 131 36 VIC Frank/Nizpro A6 FG F6 Sedan - Calder Park 10.98 @ 128 37 QLD Lee RDP/R.D.P A6 FG XR6T Sedan - Willowbank 10.99 @ 126 11's 38 QLD Gerard/Elite Automotive A6 FG F6 Sedan - Willowbank 11.00 @ 128 39 NSW ScottM / Tuff Tune A6 FG F6 WSID Sedan - 11.01 @ 129 40 VIC James333/Dyno-mite A6 FG F6 Sedan - Calder Park 11.02 @124 41 ACT - Dylan/ESP Racing XR6T Sedan - WSID 11.04 @ 124 42 VIC Jack/Bluepower A6 G6ET Sedan - Calder 11.11 @ 124 43 VIC HINRG/Nizpro A6 XR6T Sedan – Heathcote 11.12 @ 128 44 WA Walsey / UNKNOWN FG A6 Sedan - Motorplex 11.16 @ 126 45 SA Jarrad / Morpowa A6 FG2 XR6T Sedan / A.I.R. 11.18 @ 131 46 NSW KEVPW /CMS A6 FG F6 Sedan - WSID 11.20 @ 133 47 SA Jon / Morpowa A6 FG G6ET sedan / A.I.R. 11.20 @ 127 48 WA Ernie/Monsta Torque/A6/XR50 Ute - Motorplex 11.24 @ 130 49 NSW sct911 / CMS A6 FG XR6T Sedan - WSID 11.23 @ 125 ST 50 NSW LU82 /CMS A6 XR6T Sedan - WSID 11.279 @ 123 ST VIC 17 cars NSW 15 cars WA 10 cars SA 4 cars QLD 5 Cars ACT 1 car
  17. Says the guy who always complains his car feels slow just casually runs 11.2 on $20 chin wah indicated tyres. Mate well done and can you now start acknowledging that your car isn't slow and Joes tune a a good one... ha ha. Not bad for 311 rwkws! And jimmy time to borrow some ets and get back on the lisr champ.
