Hey guys, I have always wondered what is the purpose of the little hose which connects between both the heater hoses? I removed the hose a while ago, to circulate my water feed and water return for my turbo when I converted my car. Does this affect anything? Cheers
will a xr6 turbo 4spd auto bolt directly to my ba falcon n/a 4spd? Reason is that I found a bargain rebuilt box capable of handling 300rwkw +, and I need that to handle my turbo converted motor as my gearbox will fail shortly. Cheers
Hey guys, I am about to install my xr6t map sensor to my turbo converted ba. Just a couple of questions. Where is the map sensor located and how do I get to it? I will be hard wiring the new sensor, is it true that the wires need to be mirrored? Cheers
hey guys, I recently turbo converted my n/a ba falcon. I re routed the heater bypass to supply my turbo for water. Everything is fine except that my heater takes upto 15-20 minutes of driving to start heating up. Then when I change back to the cool setting it still stays on the warm air. Did my water line re routing affect this?
Hey guys, I took my car for a test drive straight after my turbo conversion without the heatshields on, I got some bad luck and a tranny cooler line blew off and the fluid spilt everywhere and caught on fire on the hot exhaust manifold. I ended up using the fire extinguisher, but now all that fire extinguisher dust is stuck on the manifold and wont come off with degreaser and high pressure cleaning. When I drive the dust starts cooking on the manifold and I need advice if its possible to wash off? cheers
hey guys, I recently bolted up a turbo setup to my ba falcon, so far its been running really good, the only thing I noticed now is that for some reason I started getting a loud air induction sound around 2000rpm just before it starts to boost and its not the spool sounds im talking about. I can't hear this sound in neutral though and I have checked my turbo for any symptons and it seems fine. Any help to what this is? Thanks
hey guys, im about to put in a turbo into my car, which has been sitting in my garage for the best part of 2 years, I got it 2nd hand but was still new then, will there be any issues that I should be worried about?
hey guys, I need someone from Melbourne that is confident to tap and drill my engine sump to connect my factory turbo return line ASAP. I don't want to go to the mechanics as they are charging me from 300-400 on labour work to remove the sump, drill and put it back in. Cheers
does the engine sump on a ba falcon contain a gasket? I am about to remove it to tap and drill it, but I am not sure if I need a new gasket or not... cheers
