chrissat
  1. hello I couldnt go anymore as it maxed out the twin 2.5 in system. the anti tramp kit is working great. it makes it a nice drift car. when I get a few min's I wll take a pic of the bent blades. chris
  2. hello the turbo has been stuffed for the last 6 months. just been keeping a eye on the play of bearings. new cartridge is on its way. also the boost has been bought in nice and easy to give the driveline a break and you have to remember its a manual and a ute , traction is a big prob. chris
  3. hello My latetest tune from the boys a BPT . Mods so far : built motor 800hp plazmaman kit ( WITHOUT PLENUM ) stock turbo with 8 pound act ( WITHOUT FLAPPER MOD ) 60LB inject fuel pump malwood stage 3 malwood anti tramp 4in dump 3.5in cat and twin 2.5in manta oh and that power was with a fooked turbo ( 2 bent turbine blades ) just goes to say you dont need a plenum and flapper mod. chris
  4. here is boost graph chris
  5. another couple of tunes.
  6. hello that's my daily driver tune. my other tune just smokes the sh#t out of my tires and is very intresting in the wet. the clutch has be replaced with a mw opt3. was sick of slipping 3rd 4th 5th and 6th gear, with my other tune. chris
  7. Hello I have more comming . plasmaman 800hp ic kit mahle pistons , spool rods , nizpro springs ,pump gears , 4in dump 2.5in twin system ,mw tramp kit chris
  8. Hello direct plasmaman ic , injectors , pump , F6 ca . custom tune im doing a rebuild atm for more power. oh and the clutch chris
  9. chrissat
    314.9 12psi
    hello I just got around to posting my tune. chris
  10. Rod or piston group buy ?
  11. hello is this group buy still on . if so can i put my name down . thanks chris
  12. hello id prob take opt 1= 4" dump and 3.5"cat - $630.00 if you can work out a price to get it to northam WA thanks chris
