Tree Monkey
Everything posted by Tree Monkey
  1. something dont sound right! In my opinion if you dont know how she would like to be proposed to and if she would want a ring then or make/pick her owne you dont understand her enough to get married. You should stop stressing and think about what her personality is like and work it out from there, dose she like supprises or is she a level headed understanding person. Are material things important to her. You need to think back over the last few years and workout what her fav moments were and this will give you a great insight in to what you do. You can even ask her what her best memories in your relationship are that's if you cant rember or dident pick up on them. Any way good luck, there arn't manny out there worth it these days..... and no I havent been married, never will as I have seen to manny f*cked up endings.
  2. is that why you allways go past there sideways
  3. bell
  4. tu tu tu! whats that skip you need an aspro. look at the cnr of the guard
  5. big na join the army or navy(fags)
  6. big size 6 or size 16
  7. I went there a few fri's ago and there was aprox 20 cars there but they close at 9 I think, had a feed and it wasent bad except they forgot most of the sides/extras. Lots of Expensive Daewoo sh*tters there.
  8. clock spit or swallow
  9. did anyone get any more pics?
  10. Tree Monkey
    Eboost2
    you need to flash tune it and remove factory boost control, then just use the eboost in its place.
  11. chicken mud or jelly
  12. I will come up on the weekend just call me or pm me the details. How about a pick of t's surounding a holden, front end's in like they are hunting it and about to kill it.
  13. SHOW OFF....... what about 1 bosch pump and tank $$$$$$$$$$$
  14. but dont we support the enviroment and promote car pooling...........(as he goes of to cut down a few more trees)
  15. what was your last car? The only reason I would steer clear of a 60 weight is the bypass in the oil pump is to small, and our pumps just keep creating higher and higher pressure the faster you spin them till the housing/alloy case splits, that is why you need to change the gears AND work the housing(from atomic). The thicker oil the higher the pressures. that's the one I posted a few months ago , some disturbing results....... not bad for valvoline
  16. What external pumps and tanks do you have chris?
  17. The boost controler works on the same/one tune. It allows the waste gate to open at differant boost levels and relies on the map sensor and o2 sensor to fine tune it. The injector pulse will only be what is needed for that boost level so if you are useing say 60% duity cycle for 12lb boost on the loaded tune in the pcm and say 70% for the 15lb tune, when you set the controler the map sensor picks up 12 lb and the pcm duity cycles for 60%, hit the button and the waste gate holds till 15lb the map sensor picks that up and the pcm allows injectors to go th 70%. Just like you only give it 3/4 throttle the injector pulse is scaled to match throttle/load and temp. Well that is what I think any way.
  18. rapid may have another type of external pump setup
  19. 10w60 what tha a little bit heavy, watch your oil pump at high rpm.... The recomended is 10w40 but go with what floats your boat, I use nulon as most on here do, would have gorn with royal purple but at twice the price I dident think it gave me even 5% more protection but will find out in a few hundred thousand kays I guess. Look it all comes down to good rep in oil, constant oil changes and a good tune in a well maintained car. The more you push it the more you service it. I do oil at every 5000k and oil/filter at 10000k cos I DRIVE it, Check it twice weekly for levels, smell and texture and anything out of place.
  20. Dont stuff around.......4"dump and 3.5"min in out cat(4-5" body) in to either 3.5" or twin 2.5" exhaust, 60lb injectors, v3 or 3.5 kit from rapid, larger fuel pump( if you can afford it go external with surge tank as they are simple to install in the ute insted of droping a tank or drilling spot welds) this will give you 350rwkw but you may have boost issues (I dident). Porting and flapper mod on the turbo is a good idear but not critical. If you do all these you will get 350rwkw on 15lb of boost and it allows you to wind it up a few pound more later if you want. Another good item to have is an electronic boost controler, at the press of a button you can go from say 12lb of boost to 15lb of boost on the fly or 225rwkw to 350rwkw.
  21. train
  22. stoned
  23. what are the colours you would prefer? What is the colour of the one you have now? if you need a white one
  24. there is more than one way to bundy!!!!!! but a little leap frog on the highway would be fun
  25. just thought I would check out AFF "glad to hear everyone enjoyed them selves, ill post up some pics a bit later, cannt wait to see everyone elses. I think we timed our run fairly well too as we tagged on to the back of the turbo falcons cruise as we headed into Maleny should ask them for a couple off their pics too as the guy at the back was taking pics from his sunroof looked pretty funny, didnt realise what he was doing to start with" dont worry mate I meen shaz I set them straight and told them who you were.
