arronm
Gold Donating Members
    119
Everything posted by arronm
  1. I didnt read 103.9mm where does it say that.
  2. I actually worked it out...
  3. Stroke would increase from 99.31 , To 103.9mm.
  4. Piston speed ???
  5. Just looking at injectors doesnt really fully tell if they have been modified. Plenty of stock drilled injectors out there
  6. Shortens the pipe work and reduces lag. Go drive a turbo territory and you will feel the difference Dont know how efficient the water to air are.
  7. Top is 20 heat range, bottom is 22 both Denso. You could re-gap the plugs correctly, most dont or wouldnt know how. Can zoom in double that
  8. This is what happens when you regap a 1.1mm plug to 0.7mm Vs a stock untouched 0.7mm plug. Back in the day when tuners regapped plugs. Oh NO....
  9. Straight from the camera. Not touched. that's the real size....
  10. Sounds like boost cut as its over-boosting
  11. The oil normally sits on top. What does it drive like. Time to check the gearbox oil.
  12. Stock car is 7 and 15.5. Maybe an LS3 will fit ???
  13. These switches are getting hard to find. Anyone with a dead one that wants it repaired or wants to sell one give me a PM. I have a guy with a GT that his button failed and a repair was attempted that destroyed the whole assembly. So any help would be appreciated.
  14. 15ml water. 45ml ethanol. that's the ratio. Try it.
  15. Changed my mind. What was I thinking. Now its time for a project car. My favorite car for over 40 years. Time to build a kit car. Have to see what powerful engine will fit. Must be quick. Doesnt need to be killa. Just faster than the original.
  16. Do you want be to work out the mL ratio, water to fuel ???
  17. The exact amout of water is critical. Dont be a tight arse. Just buy the kit.
  18. Not sure. Just buy the proper kit. It is labelled for the correct percentage.
  19. Borescope.
  20. If you dont abuse the clutch organic is OK.
  21. We only have united. E85. 107. Race blend.
  22. that's rubbish. I make more power than you and I have sprung centre. It probably wont get better. That style of clutch shouldt go in a street car. I would be making who ever recommended it to change it
  23. I had to put over 1500ks on my ceramic twin plate before the shuddering went away. I hated it. Thought I made a mistake. That was 9 years ago. All good since. Is it sprung or a solid centre. Surly no-one would fit a solid to a street car
  24. 91 in perth.
  25. If that's the case you need to supplement B12 shots (injections). My wife gets them every 3 months.
