AJJ
1 Neutral-
Hi everyone , Looking to get the centre muffler removed on my BF T ute tommorrow. Does this affect the tune on a standard car, would it need a custom tune. Also one of the reason im doing this is to get some more ground clearance, do you get much by remove the centre muffler. It has SL springs in it
Trying to find if anyone had the same problem as me, and found this topic. I've got a knocking noise seems to be coming from the RHF. The only way I could describe it would be is if someone had stuck a peg in your spokes. only makes the noise when you are moving would this indicate wheel bearing
Can someone tell me , which way the rubber joiner is meant to go on the pipe off the turbo up to the crossover There is a triangle on the part. Is this towards the engine or away. Also on the plastic pipe, on the engine side is this meant to be perfectly round , mine has a small section which is a bit flat. Also to get some knowledge, what is this pipe used for, is it pressurised air from the turbo to the engine. Or freash air for the turbo , from the air filter. Thanks Andrew
Well have finally found, where the noise was coming from, was checking under the bonnet toady and the rubber joiner from the turbo to crossover has a tear along the bottom edge with the pipe just sitting there. Has been in to Ford that many times complaining about this, and they keep saying that all connections where checked Must off had a small hole , and has finally let go. been to all auto shops to find a silicon replacement, but no luck. does anyone have a aftermarket replacement p/n they have used? have heard stories on here, about cars which where losing boost, and when fixed the computer is still suppling more boost to compensate for the leak. and then causing trouble by boosting the engine more then it should. How long does it take the computer to re-adjust. thanks
yer I agree, would'nt worry about getting an extended warranty I have it on my car, luckily it was included in the sale and I didn't have to pay for it. Every time some thing breaks or is faulty , suprisingly it is not included in the warranty and I have to pay. So its pretty worthless.
Thanks Gypo, very helpful replys. The spooling noise I refer to is the rushing air/ whistle when it comes on boost which has been getting louder, and lifting off the throttle on fast gear changes you get the ''chuuu'' or sneeze common for a turbo car. car is definately going better by seat of the pants feel. Funny you mention the panel filter, the spooling noise has been getting gradually louder over time but I never had the " chuuu" 2 weeks back, it had a ford serive and they replaced the factory filter panel and this is about when the " chuuu" started. Will have to get a boost guage hooked up as mentioned to see properly. Is there a way I could check the waste gate myself.
Well, had a look at the back of the engine couldn't see any hoses lose, haven't got a boost guage hooked up to be able to see what boost is doing. Had it Ford service and they still say all is o.k, but they really don't seem to like investigating causes to issues unless the computer tells them there is a problem. Could a car that is standard start making more boost ? Am getting the nice tutu noise from the blow off on throttle lift off, could this indicate that the blow off is now venting to atmosphere ? The car only has 50000 on it so don't know the turbo would be on the way out? Once again I do like the noise , just trying to investigate why there now appeared.
Thanks fella's Yer definately not complaining about the noise its now making, just wasn't sure if it was now making more boost then it should and not being tuned may be causing damaged. The car is definately going harder, but this may be the good noises making it seem like it is. don't get me wrong I do like it. just don't want to be hurting it . Will look at the nipple when I get home
Hope someone can tell me whats going on Have a BF XR6T manual ute, factory standard. For the past month or so I have been clearly able to hear the turbo spooling, which has been getting louder. could not before was factory quite. Have check all the hoses and there all on tight, also had a service at ford and they said they check all the hoses and there o.k. Was told they checked against other's in the yard and sounds within limits, which I find hard to believe. Now starting this week , I can clearly hear the blow off valve like an aftermarket one on gear changes or when backing off. sounds for all the world likes its had a tune, but I know it has'nt. Is there a reason a standard car would start making more boost? While I like the sounds its now making, id like to know why its now making them when before it was quite as. Does seem to be going better now, which I had put down to the cold weather. Has anyone else had a standard Xrt, suddenly become vocal.
Yer, there's no problem once it's idling, once or twice it has jumped up and down and stalled at the lights Took it in to ford, no error code on the computer so it must be in my head Have noticed when your reving it out, that it seems to give a feeling of the engine being restricted But not sure if this is just getting use to the car. Some day's you can really feel it came on boost and others you can't and it feels slow
My car is starting to develop a problem in starting, when you turn the key it is similar to having a flat battery where the engine will turn slowly 2 or 3 revolutions then fire and run fine A couple of times the engine has fired, ran ruff backfired and stalled Have done the TPS , throttle to the floor and try to start and also changed the battery, with no luck. Also doesn't seem to have the same get up and go. Has anyone else had this problem, if so what was the cause. Car only has 40,000k's BF turbo man
I had my car damaged at work, a truck drove past and its barn door swung open denting the back of the car. The damage was not that great, only a couple of dents and scrap's, smash repairer said it would take a week top's. 3 weeks later I was still ringing to see where my car was. While it was in there, I decided to get the front bumper resprayed due to driveway scrap's as its lowered. When it was finally ready went to pick it up my freashly painted bumper was all scrapped underneath, said that this could not be helped as it was lowered, still wanted to charge me full price for the job. The finish on the repaired panel was dodgy as, with run's everywhere and there was still a gauge out of the harder cover just painted over. knocked it back 3 times, as it was not acceptable work. When I dropped it off, reset the trip computer. on picking it up the figure's where Engine running time 5 hours Average fuel 99.9 ltr/100 Average speed 2kmh With half of the full tank of petrol gone. When I questioned them on this, they denide driving it. Showed them the recipt for the full tank of petrol the moring it happened. either way it had a good thrashing, probably from cold too. Don't think they realised that you need to hold the button for 2 beeps to reset, so only did the avaerage speed And to top it off they stole my 2 new fishing rods that where in the back. Apparantly they where never there, which is funny because one of the workers had commented on them. The painful thing with most insurance work is that you have to take it to there approved repairer and not one that you know will do a good job and respect your car.
G'day guys Changing the rear brake pads tommorrow BF xr6T ute, is it straight forward, anything I should look out for? Also spoke to Autopro, they said there are 3 different types Anyone know the correct part number Standard BF brakes 04/06 model, manual if it makes a difference Thanks
Spotted blue Typhoon DSL04U joining F3 this afternoon, Any one on here?
I travel the M5 everyday to and from work, and have been getting increasingly frustrated by this problem. Most afternoons it is quicker to be in the left lane where you can pass 10 cars in the right lane who are doing 90kmh with no traffic in front of the lead car , and im only doing the speed limit. I don't have a problem with people doing whatever speed there comfortable with, but do it in the left lane. And most of the people that sit in the right lane doing 10 to 20kmh below the speed limit are P platters shouldn't they be more up to date on the keep left unless overtaking, that and the fact the by law they are unable to go above 80 or 90. Another pet hate for those that known the M5 tunnel, is why do we need to slow to a stop on the hills out of the tunnel, there's no traffic light we all have to stop for. Its a hill use the accelarator drive up
