K&M in mount isa, he said he had trouble with tryin to make it boost any more than 12.5. made 317kw on 11psi and 338kw on 12.5psi, on the street it boost to about 15psi on cold nights. that's with the wategate feed straight from the turbo. did a 13.300 at 108mph at townsville. 6 speed manual, also did a 111mph. on the cold nights and boosting upto 14-15psi the clutch is sliping in 3rd and 4th so probably making a bit more power than on the dyno. another guy up here has a bf ute with 319kw with just a capa cooler and injectors and punched cat, he was running 13.5s at the strip too. the tuner said my inlet temps were the best he has seen on his dyno. think they were around 45deg run after run. another ute with stock cooler makin 275kw was round the 65degs
