Yeh its wierd real hard for me to explain but yeah one day it was fine any the next day I drove it just happend all of a sudden litilarty ill try explain a bit better. keeping in mind all gears change and go in fine the is no grinding or clunking, nothing. gearbox and engine mounts are good and the rubber seals are also good the gear stick itself is good and tight say I select 1st gear and take off hard, the box seems to twist horizontaly, the harder I give it the more it will twist 2nd gear is ok but still does it only abit though. Mainly in 1st where all the load is on the box. if I drop back to 4th to 3rd its fine, 3rd to 2nd its fine only happens when accelerating hard. if your looking at it when in first and you see the twist say I keep the go hard to 3500rpm onwards it looks like the gear is in 3rd if I go really hard it will look like its in 5th (though I havent given it that hard, im just assuming) as I said the problem is mainly from 1st to 2nd Hope this explains it a bit better Thanks Guys
