lapdog
  1. I have been to the dealer on 2 occasions regarding this problem, never once did they indicate that there was a kit available , that's why I assumed it had recently come out. Anyway fitted it up on Sunday morning adjusted up 4 clicks works like a dream and no drag.....fingers crossed
  2. Hey guys, found out that Fraud has a kit to stop the handbrake from going thru the sunroof and stop the dreaded drag that we all hear. Of course its available after the warranty period has ended. Anyway bought the kit; it consists of 2 half circle brackets and 2 funny looking springs, Has anybody fitted this.....Is it easy to install
  3. Penrith wholesale suspensions can do it
  4. You will probably find its in the slave cylinder better off replacing it
  5. I had a noise coming from my rear end and was adamant it was the diff. I pulled it out got it checked and found nothing wrong. Put it back together noise went away and I thought good however it came back after week of driving. Checked bearing in hub found left one needed replacing so did that .Noise went away but then decided to come back after another week....starting to pull my hair out by now, noise got real bad real quick so after another hair pulling session replaced right rear bearing and checked left one again....incredibly it had packed it in as well. Two new bearings later problem solved What a head%uck that was
  6. I wish my vibration was fixed that easy , I ended up having loose nuts and wrecked a wheel and a few studs
  7. You can get serious grunt out of one turbo so I dont see the need of spending twice the cash either
  8. Man that is one awesome setup how much does that manifold cost
  9. I have been stripping and snapping studs for the past 2 years on my car...snapped one last fri night on right rear
  10. Ive got new tyres and ive replaced the steering fluid already. It only seems to be very low speed like in my garage.....starting to run out of ideas....
  11. Looks hectic RE
  12. you might as well do up an NA bottom end...your much better off putting rods and forgies into it and just doing an engine swap over a weekend
  13. I agree as I am going down this path now... you are much better doing that 'cause you get more bang for your buck
  14. lapdog
    Xr6t Vs Ss
    My wife ran a guy in a new 307 the other night on our way home and you could hear how hard he was trying ...was line ball until she slowed down 'bout 300 odd mtrs
  15. Does anyone have steering shudder on their car at low speed such as shopping centre carpark etc... its really getting on my nerves.
