400KwXr6t
2 Neutral
    Perth
  1. https://s3.amazonaws.com/rmd/ford/ford-territory-sy.zip try that 146Mb
  2. Any feedback on how the uni came off to get the centre bearing off. I have the same issue. Bout to replace it but want to know how.
  3. Yeah there is a step by step on here how to do it. On my phone so finding the link a bit hard. But I know it is good and detailed. And involves a few steps of " have a beer" so it's my kind of tutorial.
  4. Yeah mine has like a rattle. Sounds like a coin somewhere. It's road speed dependent. Had most of it apart but can't find anything. May be a flap come loose or something. The fan goes flat out randomly then all works ok. It's weired and annoying its intermittent. Just when I get motivation to change the him it comes good and I don't touch it. It seems like it does it if I put the fan to full, like the variable resistor sticks or shorts to earth. Think I'll give the fan changeout a go. Seems easier than the him. Oh and the filter you seem to forget about gets pretty gross. Recommend people have a look at it.
  5. Yeah for some reason the fan and him has power all the time. So guess the him gets a bad earth In it that is random. The only way I can stop mine is pull the 40A fuse or the fan connection under the glovebox. Bought a him off eBay for $150 so I can have a play with the old one and have a backup if I stuff it up. Anyone opened a him module before?
  6. I have same problem. I disconnect the fan under the glove box which is easier than the fuse in the bonnet. Got a him module off eBay for 150 but haven't fitted it yet so don't know I this will fix it. Interested I someone comes up with a fix. I'm the same bout 2 years on a 2002 ba and does it randomly.
  7. Tyre pressure gauge maybe. With reg turned right down. An old inner tube inflated to a set psi could do it to with the gauge in line.
  8. 400KwXr6t
    Over It
    Rigs would be nice but you gotta know someone or be lucky. I've been trying to no avail yet. Mechanical fitter. Used to work on boats have bosiet and still trying. Well all good things come to those who Wait. If you wanna do something don't take no for an answer as no one else will do anything for you usually.
  9. Cheers. Link didn't work but will look it up when I'm home. I saw an aftermarket one in street machine that looked ok and wondered if anyone knew the price. The website I looked at didn't list it. And too lazy to ring them.
  10. Anyone know the part number for the 4 speed trans to drive shaft coupling. And a rough price for stock one or who to get a stronger one through. Any help is appreciated as mine is bout to go.
  11. Nullabor road house was the only place that I had to detune to 95 for. Had a couple of Jerry's too for piece of mind. Every where else I got 98. That was 3 years ago though.
  12. If they want it bad enough a tilt tray will rock up and just pull it up and off they go. Maybe some if the south African anti car jacking things. Like flame throwers that shoot up the doors.
  13. http://www.turbobygarrett.com/turbobygarrett/ Has all you need to know. How to work out a/r all the compressor maps and how to plot on them. Good read.
  14. Could be shocks. The rubber bush flogs out. If it does it over bumps this could be it.
