Sasha
18 Good
About Sasha
  • Birthday 30/04/1980
    North Queensland
1,520 profile views
  1. Cheers Nitro, They sound cool on spool. Just trying something different.
  2. Cheers mate, Not in the Isa anymore. Moved over to the coast, in Townsville now. Kenny's Garage is a workshop here with a dyno I use. Good bunch of blokes.
  3. 2008 FG XR6 Turbo Mods: 1000cc Injectors 460lph intank pump Process west cooler kit Race airbox 12lb Actuator GT3582R with upgraded .7 cover and billet wheel PAC Valve springs End result 409.4 Rwkw at 20 psi on BP ultimate
  4. Hahahahaha! I just saw the shed thread!
  5. I would use Penrite HPR GAS 10 mate. It's a 10w-50 semi synthetic and is designed for exactly that application. As for plugs use the genuine Motorcraft Denso SK20R7, they are long lasting and also an iridium plug.
  6. If big cover over small wheel + the anti surge porting = lag city, it sounds like I'm better off upgrading cover and wheel at the same time. http://www.ebay.com.au/itm/MAMBA-Garrett-T04Z-T04R-66-3-84-mm-Compressor-Housing-GTX-Wheel-Back-Plate-/171783921595?pt=LH_DefaultDomain_15&hash=item27ff1e9fbb Maybe something like this?
  7. Has anyone tried swapping out compressor covers on their stock wheeled 3582r's.....Without upgrading the wheel. I have a ported .70 cover in the garage I'd like to throw on but would like to hear if anyone else has done the cover by itself.
  8. Geez that's up there. Is there anything special about the relay? I was going to run a fused feed from the battery and switch a relay via the original pump power feed.
  9. Oh dear! I can see an aftermarket regulator in sight. I might put a gauge on it and see exactly what the pressure difference is. Are you guys using the standard wiring configuration or have run a new power supply to the sender?
  10. Is anyone using a Walbro 460lph E85 compatible fuel pump in the standard sender unit and if so was there any drama with higher fuel pressure / richer mixture associated with the swap? Cheers!
  11. Happy Birthday Sasha!
  12. Will 15" steelies fit an FG with standard brakes? or is 16" the smallest?
  13. Threw the FG on the rollers yesterday arvo at TMS Townsville and it made an easy 353rwkw at 17psi on BP 98 ULP 2008 FG XR6T ZF auto 98,000 k's Minimal Mods -Process stage 2 Cooler and piping -60lb injectors -Stock BA turbo with 9psi actuator -Stock exhaust with Center muffler removed -HP Tuners
  14. Works fine now, I sprayed the solenoid with CRC and noticed the plug not clipped on properly also. Either one of the 2 was the cause not sure, must have bumped it off while fitting new turbo.
