iotlek
About iotlek
  • Birthday 17/08/1983
    Perth
  • Interests
    Business, Tech, Cars, Science, Property
  1. Happy Birthday iotlek!
  2. Happy Birthday iotlek!
  3. Happy Birthday iotlek!
  4. Happy Birthday iotlek!
  5. Happy Birthday iotlek!
  6. There is always something to fix/replace on my car these days
  7. Thanks for the info never heard of PER4MANZ turbochargers so Ill give them a call. So hiddeous if I end up getting a new/used gt35r turbo I should replace both the compressor/exhaust housings as keeping a .70 comp housing will just cause other issues with lag/pipework that really wouldn't be worth the effort unless I plan to modify the other parts of the car to match this.
  8. what turbo you need? I have mine of a FG that's been ported, comp wheel etc for sale
  9. finding a replacement turbo that dosnt cost the earth is a pain
    1. riki83
      riki83
  10. So if I am running stock boost at the moment it might have a negative effect with more lag. So would this be more than a 500rpm difference in lag ??? Also when I get the car tuned then there could be a benefit but only if I am running decent boost(guessing above 15psi) I assume I could just replace the compressor housing as well from my old turbo essentially using just the core of the new one. The way I see it is if I leave the larger housing on then it would save some time rebuilding the turbo and I might have the future benefit when tuning the car. With the negative being a marginal increase in lag ? Also would my stock pipe work need to be changed by using the larger comp housing ??? Cheers for the help/advice
  11. Well I missed out on that core/cartridge as well. Not having much luck with this ATM . After looking around I have found a few used or new gt35r's for sale that have the compressor/exhaust housings on already but are externally gated. Is is possible to get a gt35r and then remove the existing exhaust housing and fit my internally gated 1.06 housing. Most of these turbos seem to come with a compressor housing of .70AR where as my current one is .50 could I just leave the larger housing on ??? would there be any benefit or negative to doing this if it is possible. Cheers
  12. So with something like that I would just remove my compressor and exhaust housings and install them onto the core (cartridge) plus the waste-gate actuator ?? Having never done anything like that before is it something difficult or something I could do in my shed at home ??? Cheers for the help
  13. I have been looking around at turbo's and I assume the direct replacement for the standard turbo is the gt3582r ??? or is the Ford different ? Are there other turbo's which would work and bolt into the existing location ? I just want to make sure I am looking for the right replacement. I don't mind if I have to change my inter-cooler piping etc... if needed. Cheers for any advice
  14. If its ok where did ya get the new core from ? do they have a website ? Just checked the classifieds appears its' already sold
  15. Thanks Conrad I have replied to your PM Also was wondering what is the better Turbo Oil filter MS XR6 Turbo Oil Feed Kit Including Filter http://www.mscn.com.au/Scripts/prodView.asp?idproduct=631 or FORD BA BF TURBO OIL LINE FILTER KIT EARLS XR6 FPV F6 http://cgi.ebay.com.au/FORD-BA-BF-TURBO-OIL-LINE-FILTER-KIT-EARLS-XR6-FPV-F6-/170501427061?pt=AU_Car_Parts_Accessories&hash=item27b2ad4f75 They are both about the same price but I was just wondering if one is better than the other or if they are pretty much the same. With the filter as if I replace it every time I replace the oil I would obviously want something that is easy to get a hold of. Cheers
