In respect of the temp sensing on the back of the head, yes that would be more effective means of measuring temp but the parts of an engine that are the hotspots ie, around exhaust valves and cylinder liners where the water is in direct contact with them, so if they lose that water to keep them cool then the rise in temperature to the senser will be delayed by the thermal inertia and mass of the aluminium. Itakes a finite time for the material to heat up and that heat to travel to the sensor. Also you say the sensor is at the back of the head. What about the distance from number1 cylinder/valves to the sensor. As for the condition of my hoses, from the outside they look perfect, from the inside they look perfect apart from the splits that have appeared. The failure was not a crack but a burst hose. The rubber of the hose is in good condition, no cracks, no perising, nothing. But after inspecting it very closely the reinforcing fibres that are embedded in the rubber appear to have failed and it wasn't until the cooling system got up to operating pressure that the hose blew up like a balloon and burst. The only way to have inspected this hose for this type of fault would of been to have cut it up!!!!!
