trevs
About trevs
  • Birthday 01/03/1979
Contact Methods
  • MSN
    trevor-mark-hall@hotmail.com
  • Website URL
    http://
  • ICQ
    0
    balmain
  • Interests
    anything other than working
  1. Happy Birthday trevs!
  2. Happy Birthday trevs!
  3. Happy Birthday trevs!
  4. Happy Birthday trevs!
  5. ok been away from the pc for a few days thanks for the replys ppl (1) What kind of smell? Electrical, coolant? the smell is electrical for sure that's why I pulled the fan motor out first up thinking it was on the way out but it runs,looks and smells fine (2) Got a cat stuck in there somewhere? nope no cats in there lol (3) Fresh, recirculate or both? both that's the other reason I was asking about how the car redirects the air from ,face,floor,windscreen and the like (4) auto or manual. my vents smoked when my btr sh*t itself.... the car has a zf auto and I only had the oil changed last week the smells been around for at least two months it still smells with new oil and although the old oil was dirty it didnt have any crap floating around in it (5) had this problem years ago.. do you park under trees? My system got clogged with gum leaves and would smoke at random times.. lucky it never actually caught fire lol funny you say this as the cars always parked under trees but the smell isnt of leaves I wonder the leaves may have got stuck in somewhere else besides the fan causing something to jam causing the electrical buring smell some other info I forgot to add is of late the auto head lights dont always work nor does the keyless entry ive checked the bcm and it looks fine nothing buring in there all the connections look good no hot pins or melted plugs and no blown fuses whats got me stuffed is it wont smell for a week then it stinks of buring everyday for a week besides taking out the dash I dont really see any other options as ive looked over everything you can check with the dash in and im guessing dash removel is a major pain in the ass cheers trev
  6. hello ppl anybody ever had a burning smell coming though the air vents only when the aircon or the heater is turned on everything still works and its been doing it for about a month or so and not all of the time the smell isnt coming from the engine bay and the fan motor is good as I checked that last weekend ive noticed sometimes its slow to change from the face vents to the windscreen is it possible something has burnt how are the vents controlled solenoids ? opps forgot bf t standard sound cheers any help would be good
  7. hello ppl can anyone who has cut a hole in the boot well tell me when getting the old bush out was the cars weight still on the wheels or jacked up wheels off the ground when removing the old bush just trying to plan my job befor I start on the weekend to take as little time as possible installing the new bush also whats the best size hole ppl have found if I make it the 5mm bigger than the bush should that be enough cheers trev
  8. cheers thanks mate ill upload it over the weekend and put a link here
  9. can somebody email me a copy of this the link no longer works trevormarkhall@gmail.com cheers trev
  10. Happy Birthday trevs!
  11. funny you noticed that as last night I think my car was doing the same thing and come to think about it the last few times its done it ive had the wipers on also ive gone over the brakes check the lines, topped up the fluid which was a bit low but I wonder if the reason its no longer doing it is because its not raining (no wipers on ) cheers trev
  12. And Frauds spin man will still be peeliing his banana yep said but true cheers trev
  13. if I was you id mail your flash box too your turner get him to load a safe tune mail it back max cost maybe 50bucks in postage or try your luck remember all it takes is you to forget just the once pulling away from the lights or over taking and some bad luck more so since you have wastegate mod + flapper 12lb act everybody is just guessing its going to be ok and most likely will but what if isnt in short spend 50 bucks and you dont have to worry about it still drive on carefull side or try your luck and it may cost you 7 grand cheers trev
  14. give or take 1 or 2 grand its priced about right (plus rego ) these things as are most cars are worth nothing once they are nearly two years old you them to drive and enjoy not make money plus them ugly wheels wouldnt be helping it sell as a matter of fact I wouldnt buy it just because who ever was retarded enough to put wheels like that on an xr more than likely treated the car like sh*t anyway cheers trev
  15. it sure does and in my case a few months ago did cheers trev
