SS Inductions make a Pod-in-a-box option called the 'Growler'. Advantages of this is you have a pod filter, in an air box shelted from engine heat, with a lager intake simular to the 'phoon/XR 8 setup. If that doesn't float your boat, go the 2'nd intake option. Get the XR8 one, because if you ask for the Typhoon one it'll cost you $$ due to the fact it has FPV on it!!! I have a SS Inductions 'Big Mouth' kit which is a bigger snorkle and a K&N Panel filter myself, and found that it does the trick, and a Edit will go a long way to more noise as the Turbo will be working harder making more Kw so on. My Edit has my T running 259 rwKw on 98 RON with standard internals, and it sounds great as the Turbo spools up and carrys on... All the best mate. Matt.
