Before you start....Do you have Side Airbags? (there will be a tag on the seat that says 'AIRBAG' OR You have leather seats) ? If you do don't even bother as the car Will Not run properly with the seat out, it will think the Airbag has gone off and run in Limp Mode. If it doesn't or you are just after a repair, There are 4 Bolts that hold each front seat down. You will need: 1x Set of allen Keys 1x Flat head screwdriver. Use the screwdriver and a GENTLE hand to pull off the plastic surrounds at the bottom of the seat, each one is connected to the seat base by a metal clip and breaks from the plastic rather easily, so be as gentle yet forceful as you can. Then you will reveal 4 Bolts with Hex/Allen Key heads, Loosening them is the hardest part, after that its just a sh*tload of turns before they come out. After that if you have electric seats or Airbags, you will have to pull the White plastic clip off the bottom of the seat, (it should slide off its rails/holdings). After that open up the casing (best way to describe it, you cant miss it, the plugs have to come out and there will be a clip on one side of it). Then use a smaller flathead screwdriver to disconnect/unplug the plugs and viola! The seat should come straight out. I hope this helps, its not the best description and I don't have any pics but just take your time and you should be right. Cheers,
