alpha
1 Neutral
    Perth
2,451 profile views
  1. Hey guys, is it possible to remove the side mirror compartment off the swivel base. As you can see from my I have cracked the plastic from the swivel base.
  2. Have you looked at the option of hydro dipping. There are few places around Aust that does it. I had my gear surround dipped/matched , but that was a BF.
  3. thanks k31th...yes that flat oval looking tube. I was trying to fit the growler with it in. Thanks for answer. Merry Xmas!!
  4. Hey guys. For those who have installed a Growler induction kit on their BF Typhoon/Tornado....do I leave take out the bottom air intake tube? I'm struggling to fit the kit with the lower tube on. Cheers in advance
  5. Hey guys. The white decals on my steering wheel button/control are wearing off. Any one know if replacement stickers for the BF if available. I know ebay has them for other cars/models. Cheers
  6. Thanks!!!
  7. Bugger... Thanks anyway. Looks like only option is to replace.
  8. Hi everyone. I've noticed these specks/bubbles on the inside of my headlights. I don't think it's moisture and it's only visible when the lights are on. Any ideas?
  9. Hey guys. I have a Bf ute with an after market reverse camera set up to my ICC screen. The camera does not have guide lines. My question is , if I do want the guide lines is it a just matter of changing the camera that have them or do I need to purchase a complete new system. Cheers
  10. Does any one know which Ford models were fitted with these ceiling mounted clocks. If I know which models, I can ask wreckers. Cheers
  11. Thanks for the responses guys. I'm going to try the motherboard standoff suggestion. Let's see if I can really stuff this up
  12. Hi all. My clock module cover from my BF Tornado broke. The plastic bits from the top cover holding the screws have broken off from all points. I've tried glueing it with no success . Help.. Any ideas to fix. I've rung just about every wrecker that I know of and they are all out or have not come across one. Cheers
  13. Hey Stever..had a look in the manual and don't see any fuse related to power windows.
  14. Passenger side do not work either.
  15. Hi ya Guys: Both power windows on my BF ute suddenly stopped working. I have checked all fuses under drivers column and all is ok. Where else can I check? Thanks in advance
