Boony_1981
Everything posted by Boony_1981
  1. Happy Birthday Boony_1981!
  2. HAHA, nice :D I have tried easing off the throttle until 4000rpm but it just isn't the same.
  3. Does anyone know if there is a way that a tuner can tune the boost so that it gradually comes onto boost at around 2500rpm and then goes up to full boost (rather than all boost coming on in one big lump at 3000rpm)? At the moment I'm running a 10psi tune with 259rwkw and as soon as the car hits 3000rpm in first and second gear all I get it a large amount of wheelspin. The stock dunlop tyres probably don't help either.
  4. How about water coming out from the centre console and dripping down to the drivers feet? I went for a 2 hour drive and had the air-con on the whole way. About an hour into the drive I took a hard left hand corner and a river of water came from the centre console and dripped out onto my feet for about 15 seconds and then stopped. I got out and checked that the air-con drain was not blocked because it was dripping out a steady rate onto the road. Same thing happened on the 2 hour drive back home too. Any suggestions?....Other than not taking hard left hand corners anymore and not using the air-con anymore!
  5. I had a problem similar to that. I got Ford to install another ECU and the car worked fine after that.
  6. The fix was a new ford ECU worth about $1300
  7. About $1300.....I forked that out about 2 months ago
  8. I'm pretty sure the capa tuner will still be locked with the VIN number of the other car. If you connect it up it probably won't do anything because it will detect that it has been attached to a different car. I bought mine 2nd hand and it definately needed a reset to remove the old VIN from it.
  9. Good news everyone! I finally have the car back and with a 10psi custom edit!!! Very happy with the results too, power went from 217rwkw stock to 259rwkw. I'm even getting wheel spin in 1st and 2nd when the turbo kicks in! This is great, I highly recommend a custom tune to everyone
  10. Bad news everyone! 2 weeks after getting my new PCM fitted by ford I am back to where I was before.....no boost, even feels like the car is choking when suppose to hit boost. The car was working quite well after the new computer got put it, it even did 217rwkw stock. So here I am 2 weeks later and I haven't even got my flash tuner back from CAPA yet (it was getting cleared due to the new PCM in the car) and the car is running like a dog. Time to go back to ford tomorrow and get up 'em. And to top it all off, whilst my car was at ford the front and rear bumpers have some really big scratches that they now have to fix up as well. God I love ford service!
  11. Yes the computer is not physically faulty but the car is now 4.5 years old and out of warranty. The computer wasn't computing the data from the throttle correctly.
  12. After 3 months and a stack of money later, the problem was a faulty PCM (ECU) unit.....which is gonna cost me another $1300 to fix by Ford.
  13. The fault codes should be the same with an edit. Unfortunately the problem doesn't always produce a fault code when reading the ECU. I'm having the problem and no fault codes came up when we diagnosed it. Even flashed it back to factory and still no fault codes being recorded.
  14. I found out that Ford in Townsville can test the TPS but won't release the stats on it to other mechanics so that they can't test it. And I really don't want to take my car back into ford.
  15. Well I've just rung around and a new TPS from Ford in Townsville is $213.75, but in Brisbane it's $168.45. I also found out that nobody in Townsville can test a ford TPS for a fault either. I don't know what to do. And FYI.......the TPS is the same in all BA 6 cylinder falcons, including the XR6 and XR6T.
  16. The problem is still an issue and we haven't found a fix yet. I'm waiting for the tuner to get the CAPA software so we can custom tune it to remove the problem. I should take it back to ford but it is out of warranty and I don't feel like getting stung by them again.
  17. Sweet, that would be great. Thanks.
  18. Tried the boost solenoid maintenance and that didn't work, tried a new boost solenoid and that did work either
  19. Hi Guys, My XR6T is a manual and lacking some power at the moment. I'm just wondering if the following is normal or not.....or do I have a semi-faulty TPS? 1. When coasting to a stop, should the car be idling up and down between 750-850 all the time or should it be sitting constant on something? 2. About once a month I'll turn the car on and it will idle extremely rough and almost stall (all other times the idle fine, but with the usual rocking etc.). When coasting to a stop, the car will idle between 250-750 and almost stall. I'll turn the car off and then back on and everything will be back to normal. Any other comments and suggestions are welcome because I can't work out what's wrong. Thanks, Boony.
  20. Hi Ray, If you want an edit done in Townsville then go and see Ian from Aitkenvale Auto and Dyno. He is getting the capa tuning software in soon and will be the only place in town that can actually do a custom tune (without sending the flash tuner away). As soon as the software arrives he's going to give me a call and get my car done Cheers, Boony
  21. Where abouts is the hose on the comp housing? I can't find it.
  22. Thanks for that. I am having boost trouble at the moment, so it might be worth checking the cat out.
  23. Does anyone know what the symptoms are of a dead cat?
  24. Does that mean I have to take the battery and battery tray out to have a good look at it?
  25. Does anyone have any suggestions on why I would only be getting 1-2psi of boost with the factory tune, instead of 5-6psi?
