01txr
Everything posted by 01txr
Wow didn't think the ron was that high, heard somethink somewhere that you need to set up car to run it, or am I getting confused with another green fuel. (This is the new green fuel that the V8 SC's are running now?). Is it compatable with our fuel systems and engine hardware. Excuse my lack of knowledge of the new & race fuels as always just used old super and premium unleaded fuels.
Will toluene destroy the CAT when used as 25% mix.
The angle from throttle location to first runners, just would like to know if would hurt flow to the front runners? The base plate looks pretty thin from that angle as well, have you had any warping problems. would the raised venturi's hurt flow or have you changed the design. that's great you have one 9 sec car with your plenum, are there any Plazmaman cars running 9's? just asking the questions here so don't get offended Any chance of a shot entering the plenum from throttle body flange.
No they are crap, just stay with the factory manifold. That way I shouldn't find to many T's to give me a run. My experience from fitting my plenum resulted in near 1 sec quicker et's and 18mph. It also turns tyre's 265x30x19 Toyo Proxy 4's on boost 1st and 2nd with 3rd being borderline with traction. BA 3.45 diff t56 box. Making 10psi before 2500rpm so if anything it has improved over the whole rpm range. 15psi by 3000rpm Private testing track, fried 1st & 2nd beside VE GTS from standing start, hit 3rd and disappeared (7+ car lengths) before selecting 4th and decelerating. Standard internals, x-force exhaust, Nizpro Valve springs, Siemen Deka injectors, Walbro pump, street rubber, self tuned. Fuel system hurt times as well as tyre's for traction.
And once you have fitted a Plazmaman Plenum you would never return it to standard again so drilling the lower manifold out to fit it is not any problem. Fitting the Plazmaman plenum on my near stock BA along with HDI Cooler resulted in dropping my ET from 13.9 @ 98mph to 12.9 @ 116mph with fuel surge problems in a manual. I choose the Plazmaman plenum over the PW as I preferred the angle of enterance as it doesn't by pass the first port as per the PW does and it has better enterance into each port where as the PW has raised venturi which would disrupt the flow into the runners, plus the plazmaman looks cleaner. that's my option and why I made my choice. I have seen many PW car make power though and also Nizpro Cobra. So it is a choice each will need to make on there own as they all make good power required for good street & Track performance.
just curious what size cable to run to boot mounted battery, as used to use a 2 gauge cable back with my old tuff 8's. Will a 4 gauge cable be sufficent. Also is there any issue with using a audio cable as already have a 4 gauge cable powering my amp. Will also need either a Redline or plazmaman billet bracket to suit oddessay 925 battery. If audio power cable is not usable where have you found to get a good quality cable from at a decent price. I'm also thinking of running either a trip or fuse block immediatly after battery just incase of any shorts ever happening. Will I have any problem with the trip activating when cranking engine over. Is running the power to the fuse panel right to run down to the starter and the power from starter to the boot, rather than running the power cable all the way to the fuse panel. I have run the 4g audio cable throught the grommet on the passenger side along with gauge cables & lines.
Not to mention the VCT helping to broaden the power range. It will be good, hope they get it happening earlier & hope they dont hold back on the power and increase it over future models a bit at a time. Who knows maybe the GTHO will get the 5.0l twin Turbo Bobcat engine that makes 373kw and 1000nm.
ben I ment quality not with a mobile phone and with the car not being cleaned. But anyway that huge 6" intake distracts you from the car not being clean. Adam looks like 2 weeks to the month for my car to be back on the road, so please hold off till then if you will. brother & his wife was happy with the picture of there car and looking forward to the rest.
It already does make more power than the BA/BF XR in standard. The G6ET out performs the F6 on the track in standard form as well. But what I think you where saying is what potenial the turbos have. It may not flow enough air but the BA BF cant control boost in standard form either. If the XR/G6ET Turbo is a mismatch, it doesn't do to bad on the track with low 13's apposed to BA/BF Low 14's.
Thanks heaps, very appreciated, brother LION ETR was very grateful and says thanks as well. So a big thanks to all that made it happen. great catching up with people. Cant wait to see your results of the day. so what did you reckon of Menice (CHOPYA) small factory turbo.. Pitty he didn't get to clean his car for the shoot and get some shots taken. Howsee you own a ford, dont go telling everyone we had to push start it, only holdens need push starting. LOL. How was that dungadore from the wreckers, what a piece of um every car that had come into the wreckers, hope a car comes in soon with a exhaust for the poor bloke.
Rapid Teil do a stainless housing I think for a GT45, look quite hot (LOL). Think they are around $600 to $800 from think it was VPW. The finish is as good as the Teil Wastegates.
Are the blades numbered to keep count on them for next time you inspect it. LOL must be there method for easy location of position for balancing. Wow is a lot better than Barra spec housing, still have the problem of the flapper being in the way of flow. was going to go this way but decided to go all out and go with TO4z manifold and Ext Gate Progate 50 Check this out, looks to be a good option for internal gate http://www.atpturbo.com/root/releases/release103105.htm
QUOTE (01txr @ Jun 18 2009, 09:42 PM) And cops fly backwards to. Possibly I'm not a under 25 so called hoon, but I do own a reasonably quick car, I have had a undercover car on two occassions tailgate me trying to make me go over the speed limit then pull out and pass me trying to entice me. Regular BS that comes up on here - Only BS is what you are trying to stand up for On both occassions I have seen radar gear on dash board. Usually the tell tale tail sign I had a unmarked police car blocking the right lane doing 90 on 2 lane old F3, went to pass them twice on there left and both times they accelerated to stop me from doing so, the 3rd time I down shifted ready for there games and made the pass, I found out after that they where D's and fined me for 120 in 100 zone and unsafe lane change. I had my brother in car as witness and also try to fight it at court to which the judge said he would not beleive a police officer would do what they had done. Must have been sleep driving and dreaming it had happened. Why on earth you'd want to pass a police car is mind boggling. And your readiness for there games cost you in the end. UNMARKED and why not pass a cop car doing 10 under the speed limit sitting in the right hand lane anyway. And yes GAME!, ENTICE ME TO HAVE TO BREAK THE LAW had another (Senior Sargent) pull me over for speeding, asked to see radar reading, to which he said take the speeding fine or he would do a machinery on my car, of course I took the speeding fine as it would have cost me more to get some smaller rubber and have a day off work. Whats a machinery? Were you driving a tractor? I will explain it very simple for you, a Machinery is when a cop serve's you with a defect notice here in QLD, Well that's how it use to be, I havn't had one for many years so maybe they do something different now. You have to that your vehicle to have a machinery report done for defects or modifications by the DOT, better explain that as well to you D-Department O-of T-transport. And no, if it was a tractor hell it must be one wild tractor to be treatened with speeding, something your ride is not possible of. Suppose they don't go through red lights for no reason with out lights or siren on either. It must have been a dream as a early morning in brisbane city I observed this motor bike cop do this on 4 sets of lights, I seen this as he activated the sensors at each one, to turn green for me as I approached. which was good as I didn't have to stop at any red lights through on my way home after a hard night of work. Cant speak for the banana benders, but less siren as you creap up avoids the car you want from dissapearing. IF only he was doing such a thing as heading to a crime, more like he couldn't be bothered stopping at red lights as he was in a hurry to get Mac Breakfast. Another pair of D's decided one nigh decided to fine me for doing a exagerated speed to which I said I will see them in court, guess what they decided to pull me over again within the next 1.5k's and gave me another ticket for a even more exagerated speed. Think they got a shock when I appealed it and they lost. Hope they got ther knuckles broken over it. They got paid to go to court and they should stick to detective work. Great laught this one, the brains of the cops getting handed a spanking. And yes should be getting paid to solve real crime, not make crime. Most recently a Motorbike cop caught me doing 140 in a 110 by radar and came flying up behind me at a great rate which I would have estimated to have been well over 140 and rode my rear bumper till I stopped, and yes it crossed my mind, should I brake hard or not, would have got off with the speeding ticket, just lucky I'm not a real crook or he may not be here today, that's if anyone hadn't done it since. They dont have radar as there is no where to put it. And when your doing 140, physics says they have to do a little more to catch up to you. Even if it crossed your mind to brake and cause him to come off the bike, you deserve to be locked up like the crook you claim not to be. Shows how much you know then, must have pulled it out of his ass then, glad I didn't touch it when he showed me the reading. So that makes perfect sense, Speeding puts life at risk and every K over is a killer gee he must have done many more killing K's then me. two wrongs dont make a right. And it wasn't as if I was flying pass other cars, I was the one on the far righ lane of a group of cars all sitting at near spot on to my speed, and me being in a tuff black AU XR8 compaired to there common import crap was the reason for being singled out of the bunch. and you say I am a crook and deserve to be locked up ha, dont fart people you may get locked up. If you think cops dont do no wrong you are so full of it, just because it hasn't happened to you doesn't mean it doesn't happen... Get a hobby I have its called earning enough money to keep the revenue raising scum fed. Sounds like you are a cop or a want a be cop, if so go catch some real crooks or are you afraid they will hurt you. I will say these have been a few bad apples in a bunch, you get your good and bad everywhere. I do have friends who are officers and not bad people, but you do learn how they like to provoke people when they get bored. How funny they think they are when they abuse there authority, but hay they are nice people socially. I.B.
And cops fly backwards to. I'm not a under 25 so called hoon, but I do own a reasonably quick car, I have had a undercover car on two occassions tailgate me trying to make me go over the speed limit then pull out and pass me trying to entice me. On both occassions I have seen radar gear on dash board. I had a unmarked police car blocking the right lane doing 90 on 2 lane old F3, went to pass them twice on there left and both times they accelerated to stop me from doing so, the 3rd time I down shifted ready for there games and made the pass, I found out after that they where D's and fined me for 120 in 100 zone and unsafe lane change. I had my brother in car as witness and also try to fight it at court to which the judge said he would not beleive a police officer would do what they had done. Must have been sleep driving and dreaming it had happened. had another (Senior Sargent) pull me over for speeding, asked to see radar reading, to which he said take the speeding fine or he would do a machinery on my car, of course I took the speeding fine as it would have cost me more to get some smaller rubber and have a day off work. Suppose they don't go through red lights for no reason with out lights or siren on either. It must have been a dream as a early morning in brisbane city I observed this motor bike cop do this on 4 sets of lights, I seen this as he activated the sensors at each one, to turn green for me as I approached. which was good as I didn't have to stop at any red lights through on my way home after a hard night of work. Another pair of D's decided one nigh decided to fine me for doing a exagerated speed to which I said I will see them in court, guess what they decided to pull me over again within the next 1.5k's and gave me another ticket for a even more exagerated speed. Think they got a shock when I appealed it and they lost. Hope they got ther knuckles broken over it. Most recently a Motorbike cop caught me doing 140 in a 110 by radar and came flying up behind me at a great rate which I would have estimated to have been well over 140 and rode my rear bumper till I stopped, and yes it crossed my mind, should I brake hard or not, would have got off with the speeding ticket, just lucky I'm not a real crook or he may not be here today, that's if anyone hadn't done it since. If you think cops dont do no wrong you are so full of it, just because it hasn't happened to you doesn't mean it doesn't happen...
Ok just would like to know as I haven't gone through the 14 pages but whats the go with pictures, do we get image files or what is the go with keeping a picture or more of our cars from the shoot. Just want to let a few people know one being menice currently looking on here and my brother lioneta. Can you PM me a contact as brother is having pc issues so he can book a time for his FG XR6 Also just have to ask if its ok to come check it out as my car is still off the road unfortunly but wouldn't mine checking out some of the cars and how its done.
Dont gamble your engine on valve springs, if people are saying they have had problems at 320 rwkw well best change them. One stray value will destroy your engine. Fit valve springs set you back under $1000 you dont want to add a engine to the cost.
Suppose since I suggested it I will have to show my not to shabby lady who is 40 and mother of 4. please dont be to harsh. Not a glammor shot either just a picture of us about to head out for the night. Sorry for my ugly mug in the picture. I reakon the rear on the model wouldn't be as flat as you may think if she was standing with legs together in that shot.
As stated in the other valve spring post, valve springs should always be installed at specified height to obtain correct seat pressure. I have Nizpro springs in mine installed by previous owners mechanic, must be alright as I have done over 30 000k's on them myself and they have seen 20psi @ 6500 with no problems. For my new engine whenever it happens I am going for Comp Cams conical springs have part number & specs somewhere from back months ago when I was pricing all bits up. I cant rember the specs but recall the price to have been around $580 wholesale. The seat and open pressures where very good and think the retainers where included. Sorry I cant tell much of them at present but sure if you did some searching you will find them. They may have been a v8 set to being USA made.
Dont worry about it overboosting as I have run mine for well over 12 months with it over boosting up to 20 psi on cold night and mornings, and mine is a BA series one which has weaker rods. Your ecu will correct the afr to a certain point or limit it if it is required with its adaptive learning. Buy yourself a wideband o2 gauge to keep a eye on the afr's just to be safe or have it dyno'd. keep in mind if it is all factory standard including tune it has been tuned for worst case senario and run slightly rich mixtures from factory. So what boost is it pushing and when you drove it what was the climate like.
So have I missed this or not. Would like to come and watch as well. is it cort or tv who is organising the shoot or someone else? If I have missed it would it be possible some time in the near future to be able to get some pictures of my car and wife done once I get my car back on the road. And no she is not a 10/10 glammor, just would like some top quality pictures done of my car and lady not me as dont want to ruin the picture.
You have to be kidding worst ass, so I take it your ass is better, no we dont to see it and judge but man get real its not that bad. And yes she is pretty average and not a glammor like some, garrantee she would get more attention than yourself. I would rate her a bit better at 7 of 10 Best ever aussie chick car photo shoot I have seen to date. Nice work. Instead of people bagging the model and car how about posting up pictures of your own cars and model before dishing others. So YPURV4 where's the pictures of your women that is better than this model, we are all waiting to see if what you say has any cred.
ben chop off 2 sections of the bump stops this had helped mine but didn't cure it. With yours being standard height but softer spring than mine it may be coming down and bouncing off the bump stops as mine was.
Protect Yourself When Buying Big-dollar Parts And/or Work
01txr replied to straughsberry's topic in Off-Topic
At least tell us what state to be careful in. Feel sorry for you, had same senario a few years back, gave a deposit for 2 sets of Elderbrock Alloy heads, one for my everyday 351w Cortina the Other for my XY Gt Rep. Anyway get to the point, and friend of mine recommended him, should of stayed clear concidering my friends engines kept breaking. I gave him $3000 and didn't see the heads, he kept saying all sorts of excuses saying they had been sent to wrong address, that they where held up in customs eta eta. I ended up enquiring to a local speed shop to see if they had any in stock when they said to me this con had only been in there today asking if they could get same heads I was chasing. I ended up fronting him and he gave my cash back, maybe bit worried because of my agressive nature for him to hand it over. I though it was going to go down badly and was shocked that he did hand it back. My daughter also had a work colleque/best friend sell her a car with her making payments over time period and car to be handed over at set date. I warned her from the beginning that this guy was going to rip her off and made her get sign agreement from him. She was only working part time and we had allowed her not to pay us board as she was doing something with her earnings and not blowing it on crap. What guy sells a car but continues to spend money on it, god my daughter has learnt on this one. She had paid him $5000 with $1500 owed. I even took the balance to him and damanded he hand over the car. He refused to take the balance saying he didn't want to sell it now. I then had a friend pick it up with his tilt tray and took it home. They followed us back to home and had the police turn up. We told them what this scum had done and showed the police the receipts and the cash balance we tried offering him. We ended up having to return it to him and where told they could have prosecuted us for stealing it they could see the situation and wouldn't prosecute, they recommended us to get legal with it. Strange how you can get ripped off by someone like this, The scum should have been charged with fraud not to mention my daugther being a 15 yo when he took advantage of her. We tried legal aid but all they did was give us a form and said to fill it out, the dam thing was more related to a loan then purchase of a car. Filled it out and she took it back. She was told we had done it wrong but did not offer her any assistance to corect it. All I can say is this maggot will get just deserves. Dont kid yourself, people will rip you if you are not careful. -
Still dont have any idea on what you are on about. Is it not aligned properly or rubbing on something, you need to explain better. If the belt just keeps wearing out and snapping it will be due to alignment or a pully bearing problem as in the belt tensioner or it could be a tight water pump. My belt has been on my 2003 BA XR6T for like 126 000 k's, looking a bit worn out but havn't any issues and I am making well over 350rwkw. If your pulley is faulty PM me as I have a Powerbond 20% underdrive balancer brand new in box that was going to be used for my new engine but I have decided to go with a differnt balancer due to the level of power I will be chasing. Will take $220 for Pulley if you are interested. You will need to purchase a shorter belt which I can also provide the part number for. these 20% underdriven balancers free up power as well.
Great link there Pube. My suggestion would be to run a canister as per the very last picture but fit a gauges filter internally to the exit side of approx 20microns so it allows fume only and keeps as much oil away from the exit. Other than that a baffle just below it .
