wilsn
About wilsn
  • Birthday 15/10/1982
Contact Methods
  • Website URL
    http://
  • ICQ
    0
    S.E. Melbourne
  1. Happy Birthday wilsn!
  2. Happy Birthday wilsn!
  3. Happy Birthday wilsn!
  4. Happy Birthday wilsn!
  5. Happy Birthday wilsn!
  6. I HAVE A SEDAN WTH 225/35/20 ON THE FRONT AND IT FITS FINE. HAVE USED THE TYRE WITH 35 AND 39 OFFSET AND BOTH WORK FINE. Did someone say that they can run 255/30/20 on front as that's what I want to do?
  7. superpro make a shorter version, ive had them installed for 2 years with no probs.
  8. Does that mean that all turbo territorys (SY) come with the stronger f6 rods?
  9. As stated in a previous post I have had problems with my tune from HP-F from day 1 with back firing and loss of power at 4000 revs and onwards on hot days but they could never find the problem, went back three times and they just keep giving you the run around. I am going to just have to go somewhere else to get the car tuned properly. Hopefully they can find your problem, Good Luck!
  10. These guys sell them on ebay. http://stores.ebay.com.au/AUTOSPORT-DECALS Post up some pics if you get them.
  11. hi, my diff cover went about 6 weeks ago but I had to get it fixed fast so I just got the standard ford cover and bush, there is a stronger aftermarket bush available from fulcrum suspensions PH:1300 651 551 But im not sure whats available on the actual cover.
  12. it definately is not hitting the rev limiter it just revs happily to 4000 rpm and then wont rev past that, but before they regapped the spark plugs it used to occasionly backfire if you kept trying to push it past 4000 rpm.
  13. They said they put it on the dyno last time I took it there and complained about it but couldnt find anything and said they regapped the spark plugs as they suspected they were the culprit but it is still exactly the same.
  14. yeah they just say they would have to experience it but that is almost impossible as it only does it on really hot days after driving more than an hour and they are only open week days when im at work.
  15. hi, I had a new edit done a few weeks ago through hp-f and ever since on a hot day (30 degrees+) after an hour or so of driving the car will only rev out to 4000 rpm at wide open throttle, but then if I let it cool down for an hour or so without driving it it will behave normally again. If anyone has a solution please tell me as we cant work out what it is?
