rhys86
Everything posted by rhys86
  1. Did you end up getting a price for a 9inch conversion??
  2. I have it done. talk to etm one of our site sponsors. he has a nice kit
  3. What was going wrong with your launch and what did you have to do to fix it??
  4. Top effort. Great result. What psi are you leaving the line with??
  5. Any info on the drive shafts??
  6. I just want a rear end that will stay together like that. Remarkable effort leaving the line with 19.5psi. I wish I could do that.
  7. Mate of mine has it on his skyline and I was wondering what it was like but that answered the question for me thanks.
  8. What power do you guys think this turbo would be capable of handling. It has similar specs to the HKS T51r SPL. Here are the specs of the turbo Intake :4 inch Outlet: 2.5 inch Compressor trim: .70A/R Compressor Wheel diameter 76.80mm / 102.35mm Turbine Wheel diameter 64.56mm / 74.12mm Exhaust trim: .81ar Turbine flange type: t4 flange Downpipe flange type : 3 inch v band flange Cooling type: oil and water cooled Any ideas of what power it would support??
  9. Lovehe cage looks great. Who did it for you??
  10. Where did you getthat rocker cover garnish from or made at?? I like it alot.
  11. rhys86
    First Mods
    Depends what kind of power that you are looking for. First of all get yourself a flash box and that way you can at least get it tuned. That should get you to about 250rwkw. After that in an 03 your prob going to have to do valve springs injectors and intercooler. That should see you around the 300 mark. AFter taht prob turbo work (wastegate and flapper mod). That would see you into 300's. If you search you will find heaps of threads relating to mods to kw output.
  12. Any updates on the car?? Also you got any pics or sound clips of the beast??
  13. I have them. They don't make the car as lumpy as the video that is on you tube. The specs aren't that far off the standard bf cams. Basically they gave me a bit more mid range power. They are harder for tuners to tune but its alot of money just for the wank factor. If I was going for wank factor I would get bigger than the ones I have. Your fuel consumption goes out the window and obviously the bigger you go the more undrivable it gets on the street. I can get a sound clip if you like so you can hear what they sound like.
  14. That would be bloody scary. It would be iteresting to know what he has in the rear
  15. So you leave the line with 19.5 PSI? Is that right?? What CV's are you running or what has been done to them?? I'm looking at upgrading mine.
  16. Have you got any pictures of the fuel cell in the boot?? Great result with a stock bottom end.
  17. Does anybody no what omage the fuel sender is on t's?? Is it 9 ohms or something different??
  18. We could just do a natio run. Easy and fast to organise. Great fun as it has been in the past. What do you guys think?? Could just have it on a Friday/Sat night it the next couple of weeks??
  19. rhys86
    311rwkw
    Had the car at CV today for the final race tune. Dyno graph speaks for itself. Nice vertical power curve.
  20. What kind of turbo did you end up getting??
  21. What mods has it gt besides the 3 banger?? Got anymore photo's?? Very hot looking car
  22. Very nice ride. I should have got a ute.
  23. If you are going to run a screamer that's the only thing that you have to modify If you aren't going to run a screamer then the dump pipe will have to be modified so that the wastegate is plumbed back in.
  24. Jut got the video today. Will post a link when I get it onto the computer. I just ran the car up on the transbrake until the gate cracked open. So it is slightly louder than if it was moving Will be up shortly.
  25. You jus need toget a bell housing made, tailshaft and either geta custom cross member made or just modify the one that you already have. The cross member in mine is just a 5 spped manual cros membr modified to take the c4.
