Boy have you got some reading to do! For the Typhoon option, see the following topic, http://www.fordxr6turbo.com/forum/index.ph...topic=19583&hl= The other easy option is to go for the edit, with 8-10 psi tunes, which should give you between 230-260 rear wheel KW, that is without changing anything else. The other simple mods are a second air intake & replacing the centre muffler (mainly for better sound!). If you have an auto, a transmission cooler is also a good idea. There has been a lot of 'discussion' about injectors, but for these mods the standard injectors seem to be fine, if you want more power then an injector change will be required. But be warned, if you start modifying, you might never stop, need more power, need more power,.......... Aaron.
