4ST-XR6
Contact Methods
  • Website URL
    http://
  • ICQ
    0
  1. If the car only got better for a few days the solenoid could be sticking to the point where the spray doens't have a lasting effect, you could try a borrowing a mates solenoid who has had success, then buy a new one and lube it regulary from day one. I'm yet to actually monitor the solenoid duty cycle with the pds and make recordings before and after to get some hard evidence that it works, It feels like it made a difference to my car and other people agree, just wanted some figures just out of curiosity
  2. Thanks mate! Please tell me as much info as you can guys. My boost control is shocking ATM and I get creep up past 1 bar in the top end, and I haven't even fixed my 3" exhaust which has been damaged and is probably restricted to 2.5 inches. How big is your exhaust? Its very difficult to set a flat boost curve how it is. I can't see how you got it ported out 6mm without a new flap valve though. It appears as though there is only about 2 or 3mm overlap with the stock flap. ← I think he said that the circumference was increased by 6mm, if you say there was 2-3mm overlap I imagine that would be plenty because even banking on the smaller option the diameter of the bore is still approx 4mm greater than the flapper, and increase of that diameter could increase the circumference by approx 6mm (circumference of a circle= pie(3.14)xdiameter. keep the updates comming both of you, Im gonna have to do the same mod soon.
  3. Never in any time that Ive openned the turbo section of the workshop manual have I heard ford refer to thermosyphening, I understand the concept and if it is used well that's all well and good, but I agree with rotor motor about the bearings in the turbo being damamged when the oil temp rises after the engine and hence oil pump cease to operate. I spoke to a region SOC (service operations co-ordinator, or something like that) and was told the reason xr's don't come with them is because these cars are built on a budget, If that was the case and the hardware wasn't needed I'm sure ford could have created the engine management to allow the the car to run after a period of "spirited driving". So pretty much each to there own. This and other issues Ive tried to get answers from ford and even being an employee your just a mushroom (kept in the dark and fed sh*t).
  4. Id be going for wastegate issues straight up, what kind of boost are you running to attain those rear wheel kw figures, that's phenominal, A friends car is making the same noise, it had a custom edit 10psi edit done, then since the tune has fitted AVO cooler, 4inch dump, high flow car, and exhaust. It requires a retune as it is overboosting, Ive heard of this problem few times after exhaust/cat mods, and Ive seen cars that have a had a edit for 10psi, then the mods were done and the car was overboosting like no tomorrow, something around 16-18psi from memory, this is no good for standard rods in any model and If you have a mk1 like I do its even worse. Id be getting you car looked at asap mate, Im pretty conservative and would run about only 10-12psi. A few guys will agree, and a few wont but theres no point making bulk horsies that arent reliable unless you have a huge wallet. Good luck mate Cheers Mic
  5. Kristie, let the boy paint his car.hahahaha.
  6. Yeah gav, bring the black down to the body line, but keep the gold pinstripe to match the rims.
  7. Just had a thought, gav you get the drift6 bonnet or a side mount cold air intake similar to the one you had on the EL off the sequential xr8. Ypurv4 could you photo chop that, it would look tits. The reason I ask is I am extremely computer illiterate, and that's no exageration. lol
  8. Gav we've been mates a long time and you know I'm not a big fan of the wank wank two tone bs but honestly what ypurv5 has done looks brilliant, and the gold pin stripe matches the gold centers on the 20's. So when you gonna go midgy to paint it....... Is he still at ellis' or would deano do it???
  9. Race it how you drive it on the street....There are too many skylines and supras that head down the drags, gut the interior and pull the stereo out, others are running slicks and brag about how fast their car is. After all it is street category.
  10. that's a steal mate, go for it.
  11. We had an ex police chaser get traded at our dealership, white xr6t. The only things it had was the police mode digital speedo, and the upgraded brakes with the ford blue/black calipers(not brembos) with the eliptical slotted rotors, but I have seen one other turbo with the same rotors, and as far as I'm away the rotors were the only difference, the calipers were still a 2 piston sliding housing type on the front, and single piston sliding housing on the rear.
  12. Another perfect example of how ferocious a woman can be. "Hell hath no fury such as a woman scorned". Well I think that's how it goes. lol She is just pissed off caues good ol pete refused her a good rogering one night, and wanted some cash and the house, she couldn't make the allegations when he was alive because she knows that she doesn't have a leg to stand on, so is on a mining expedition after now the poor bastard had left the building. Full credit to Bev, top woman.
  13. Everyone has heard the police force deny claims they have a quota and we all know its BS, several weeks ago I was in a friend of mines car, he has a scanner, we overheard a conversation between dispatch officer and the officer in a marked car which had the hair dryer out, on the section of road we just drove down. We heard dispatch officer ask "how are you goin 202?" to which the officer replied "quite good, 2 to go and I will be packing up". So no quota my ASS!
  14. I wasin on gav's install, like he said, not too difficult, make sure you have a die grinder, you have to grind out the section under the battery mount, where the factory aluminium tube runs, due to the avo pipe being a larger diameter, only other structural mod is the from support behind the bumper, again, use the 4" grinder once you have marked out the areas you need to cut, then use the die grinder to finish it off. cheers Mic
  15. I have seen a black 380 getting around my area, low with 19 inch rims, doesn't look too bad actually. Wouldn't mind going for a blap in a blown one. Also there is a few aurion's getting around, trying to make a bigger aussie car to rival the Late model camira and falcon, its never going to match the sales figure of Expensive Daewoo and ford, but the solution is very simple.........rear wheel drive. lol
