1600+ Cc Injectors...
  • Sandtrap Motorsport
  • Member For: 16y 1m 2d
what 1600cc (160 Lb) injectors (or greater) are there for XR6Ts?
if anybody can get them for a good price, please post or PM me (if you want to be discrete).
trade price would be nice if possible.
probably going to run the Phoon motor on methanol now, since the cost of Dry Ice boxes are like "phwwooarr" haha.
  • Member For: 17y 4m 8d
Indy Blues are 1680cc I think. Them are some big injectors. But you wont find a high-z set to suite. The biggest I found were 1000cc and they are milled Bosch EV14. You'll have to get (or make) a high-z to low-z converter. Or run maaaaaasive fuel pressure :)
Motec drives high or low impedance injectors so Indy Blues will do the trick. They are rated at the usual 3 bar. I remember from doing my research that your fuel delta (fuel rail pressure + boost pressure) determines the total pressure your fuel pump/s will have to work at. So then you can see if your pumps will supply enough flow to feed the injectors at that pressure.
I did this thread a while back. It may help...
