SAPNEN Donating Members 278 Member For: 16y 7m 9d Gender: Male Posted 03/02/09 11:01 PM Share Posted 03/02/09 11:01 PM (edited) Ok I noticed no one has put pics up of this... which wasn't much help to me yesterday, so hopefully this helps others. You will need: 13mm spanner (intercooler bracket nuts) Phillips head srewdriver (all those fun plastic screws... yay) 6mm socket (under tray screws) 7mm socket (pipe clamps) 10mm socket (I think its a 10, for between the head light bolts) socket extension arm lots of patients and small hands (intercooler bracket nuts, plastic srews) loud music and a couple of scotches...I started with removeing all the screws in the undertray, don't forget the 1 in the centre on the rear. Also the 2 plastic screws at each end are a pain but will push back in ok later even if you give them a hard time pullen em out... There is 1 metal screw and 2 plastic which you need to remove, turn your wheel to get to it easier.There are 2 tech screws in these holes behind number plateOk, remove the 2 plastic screws from the top grill ( I hope you have your bonnet open..!) and pull up, there are 3 plastic tabs at the bottom of the grill so be gentle when lifting out.Remove the 4 plastic screws holding the plastic shroud and pull out, there is a clip in the centre holding it down so remove gently.Now finally you should see these 2 metal hex head screws inner from the head lights, remove them.Now you might want someone to help with this so as to not let the front spoiler hit the ground, failing that leave 1 screw in loosly. Pull spoiler out from the wheel arch on both sides and it should be freeDisconnect the fog lamp plugsNow there are 2 brackets holding the intercooler in with 4 bolts, release the pipe clamps, and pull the pipes out of the way. Remove the 4 nuts holding the cooler (this is where you need patients and small hands). Pull the intercooler down (right side first) and gently remove it with out putting pressure on the A/C radiator fins (what I'm saying here is do not bend any cooling fins on anything!)Now with your cooler removed give it a spray, I went for silver. It only needs a light spray, don't go over board and block the cooling fins. I also only painted the front...Now working in reverse from before put the cooler back in and it should look like this... Don't over tighten the pipe clamps.Put everything back together, the front spoiler will go back on easily, don't forget to reconnect the fog lights. Put your grill back on etc. If you end up with spare srews you have failed as a man and need to take a good hard look at yourself! I think the cooler would be more noticeable without a lower grill or if the lower grill were black but meh... I like it!Have fun Edited 03/02/09 11:02 PM by SAPNEN 3 Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 9m 29d Gender: Male Location: Sydney Posted 03/02/09 11:17 PM Share Posted 03/02/09 11:17 PM Thanks for taking the time to write this up Link to comment Share on other sites More sharing options...
Jake F6 Donating Members 327 Member For: 21y 4m 29d Location: Melbourne Posted 04/02/09 12:38 AM Share Posted 04/02/09 12:38 AM Cheers for the great instructions and pics! Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 5d Gender: Male Location: North of The Bridge Posted 04/02/09 01:50 AM Share Posted 04/02/09 01:50 AM good work mate, maybe re name the thread "how to remove the front bar" and make it a sticky somewhere.. its alot more usefull then the current title Link to comment Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 21y 11m 7d Gender: Male Location: Not sure? Posted 04/02/09 02:01 AM Share Posted 04/02/09 02:01 AM There is an easier way to do the stone tray. Undo the single bolt in the centre at the back, and then remove the bar as listed. This way you don't need to undo 8 or 10 screws and it gives the bar something to sit on. Link to comment Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 16y 8m Gender: Male Location: New Zealand, Palmerston North Posted 04/02/09 04:16 AM Share Posted 04/02/09 04:16 AM that's just the stock cooler a? I have wondered about doing that... looks not bad Link to comment Share on other sites More sharing options...
SAPNEN Donating Members 278 Member For: 16y 7m 9d Gender: Male Posted 04/02/09 04:28 AM Author Share Posted 04/02/09 04:28 AM There is an easier way to do the stone tray. Undo the single bolt in the centre at the back, and then remove the bar as listed. This way you don't need to undo 8 or 10 screws and it gives the bar something to sit on.Nice one! Wish I had'v done it that way Link to comment Share on other sites More sharing options...
SAPNEN Donating Members 278 Member For: 16y 7m 9d Gender: Male Posted 04/02/09 04:29 AM Author Share Posted 04/02/09 04:29 AM good work mate, maybe re name the thread "how to remove the front bar" and make it a sticky somewhere.. its alot more usefull then the current titledon't know how... 1 Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 7m 15d Gender: Male Location: central coast Posted 04/02/09 04:39 AM Share Posted 04/02/09 04:39 AM should still be 2 or 4 screws that need removing they hold the inner gaurd in place at the bottom of it Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 3m 8d Gender: Male Location: Southern Highlands NSW Posted 04/02/09 05:23 AM Share Posted 04/02/09 05:23 AM Nice workYouve just earnt your self a sticker 1 Link to comment Share on other sites More sharing options...
