hanra Into the laaaake Member 1,532 Member For: 17y 11m 23d Gender: Male Location: Nrth Qld Posted 02/03/08 11:33 AM Share Posted 02/03/08 11:33 AM (edited) So ive started installing a 2L surge tank and Bosch 044 pump into my ute. Parts ive used so far. Bosch 044: $200Mounting Braket: $42Tank: $1403/8 & 5/16 EFI hose/clamps: $75Speedflow checkvalve/fittings: $105Aluminum Plate: $0Wire/Relay/Bolts/Connectors/Misc: $60Keep in mind that some of these items have freight added on also.The plate I used is 330mm long, 160mm wide and 6mm thick. I just happened to have some laying around so it did the trick nicely. Ive bolted it in 5 places using 3 10mm bolts and 2 8mm bolts. I just used existing holes in the ute. For the wiring, ive spliced into the 12v supply from the stock pump (pink wire) and ran it to a relay. For the 12v supply for the 044 ive spliced into another pink wire which has constant 12v on it which runs to the towbar connector. Not sure what its use is. Ive concealed all the wiring that ive run within the standard loom. Ive fused that 12v supply with a 20A fuse as close as possible to the relay. Ive mounted the pump to a vertical section of the tray. The lower hole was tricky to drill as you need a short drill and you have to get to it from under the car.... Its a tight squeeze. The top hole is simple. Im going to try to insulate the braket with some rubber.Im yet to mount the tank or run the fuel hose as yet. That will be a job for later in the week when the tank and speedflow fittings arrive. This is the tank, its just a cheapy: This is what I have to start with: This is what ive done so far, stay tuned: Edited 02/03/08 11:37 AM by hanra Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/ Share on other sites More sharing options...
groper Member 611 Member For: 18y 4m 5d Posted 02/03/08 12:08 PM Share Posted 02/03/08 12:08 PM copy cat lolbzzzzzzzzzzzzzzzzzzzz is comingrubber mount that bastard good ay Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-640944 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 11m 23d Gender: Male Location: Nrth Qld Posted 02/03/08 12:15 PM Author Share Posted 02/03/08 12:15 PM Hahahahah! Yeah I know. I studied that pic that you put up in another thread!!!! hahaha! Yeah im going to try and get some exhaust hangers, that have a thread either end but are seperated by a block of rubber. Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-640948 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 2d Gender: Male Location: Townsville Posted 02/03/08 04:21 PM Share Posted 02/03/08 04:21 PM Did you find it easy getting the plastic liner out and do you know if you can get the standard fuel pump out this way or is that beam in the road? Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641008 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 11m 23d Gender: Male Location: Nrth Qld Posted 02/03/08 09:05 PM Author Share Posted 02/03/08 09:05 PM The tub liner is easy as!!! 12 bolts and 4 screws and its out. 2 man lift though. I doubt you would get the pump out that way, yes there is a beam in the way. Perhaps you could undo the straps for the tank and shift it slightly to expose the entire pump? Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641017 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 21y 10d Gender: Male Location: Mackay NorthQueensland Posted 02/03/08 10:10 PM Share Posted 02/03/08 10:10 PM how come you just didn't use the Process west swirl pot ? bolts up in ten minites, and is only a bit more. must be a reason, just wondering what it was. you get more noise from the back of the ute then the front, or did you not expect it to add up to so much, or just wanted to do it yourself? David Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641029 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 24d Gender: Male Location: syd south Posted 02/03/08 11:12 PM Share Posted 02/03/08 11:12 PM I reckon you have done the wiring wrong.you need a good power supply to the 044,something like a 4mm wire direct from the battery to the relay and fuse it as close to the battery as you can.that wire you have tapped into may not big enough and you will find that it is fused back in the engine bay with maybe a lower amp fuse than the 20 amp the 044 needs.take the time to run proper wiring or you will have dramas more than likely Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641047 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 21y 10d Gender: Male Location: Mackay NorthQueensland Posted 02/03/08 11:40 PM Share Posted 02/03/08 11:40 PM $200.00 is cheap for a 044, is that a genuine one, because there are copies on ebay, if it is genuine, I must be getting riped. David Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641067 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 11m 23d Gender: Male Location: Nrth Qld Posted 03/03/08 12:13 AM Author Share Posted 03/03/08 12:13 AM I didnt expect this to add up to so much. The PW tank is $600ish without a pump I thought I could get out of it a bit cheaper. In hindsight though maybe not. I like to give myself projects to undertake on the weekend. This is the pump: Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641077 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 24d Gender: Male Location: syd south Posted 03/03/08 01:35 AM Share Posted 03/03/08 01:35 AM yep that's a genuine 044 Link to comment https://www.fordxr6turbo.com/forum/topic/43198-ute-surge-tank044-installation/#findComment-641129 Share on other sites More sharing options...
